  Left Front Directional and Parking Lights only working when Turn Signal is on.
Left Front Directional and Parking Lights only working when Turn Signal is on. by Steelers8
Started on: 04-05-2021 08:53 AM
Replies: 10 (201 views)
Last post by: Steelers8 on 04-07-2021 11:03 PM
Steelers8
Report this Post04-05-2021 08:53 AM Click Here to See the Profile for Steelers8Send a Private Message to Steelers8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just pulled all bulbs to replace since I just bought it and now not working. Parking light now has power to both pins until I put Directional on. I am sure it is a ground bad right?
KCBSR
Sledgehammer
Report this Post04-05-2021 03:11 PM Click Here to See the Profile for SledgehammerSend a Private Message to SledgehammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a ground problem, However, try your 4 way flasher. If all directional bulbs flash normally then actual problem may be your turn signal flasher located under the dash.
Report this Post04-06-2021 06:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Iffy sockets often have ground problems... for front back or all.
See my Cave, Lighbulbs and Sneak Path
84 also have relays in back to use 3 bulbs per side for brake/turn.
Tony Santucci
Report this Post04-07-2021 05:53 AM Click Here to See the Profile for Tony SantucciSend a Private Message to Tony SantucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year?
Steelers8
Report this Post04-07-2021 05:54 AM Click Here to See the Profile for Steelers8Send a Private Message to Steelers8Edit/Delete MessageReply w/QuoteDirect Link to This Post
1986
Mike in Sydney
Report this Post04-07-2021 09:43 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you using LED bulbs. Also, it's a long shot but have you checked or replaced the blinker relay? It's near the fuse panel on the left side of the car.
Tony Santucci
Report this Post04-07-2021 03:17 PM Click Here to See the Profile for Tony SantucciSend a Private Message to Tony SantucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure the Park/Turn lamp bulbs and stop/tail/turn bulbs are dual filament bulbs. 1157 or whatever.
Report this Post04-07-2021 05:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
2057 is OE but 1157 or 2357 works.
2357 is bit brighter bulb often use to "upgrade" Fiero and others. May not be legal but no-one cares if used w/ red lenses. (Amber lenses like GT rear taillight set + brighter bulbs often blinds other drivers. almost as bad as crap headlights.)
LED's causes or have many problems even ignoring illegal for street use.
Steelers8
Report this Post04-07-2021 10:05 PM Click Here to See the Profile for Steelers8Send a Private Message to Steelers8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you all! It was the front left directional socket even though it looked good! Much more to do so I will be asking for additional help.
KCBSR
Xenoblast
Report this Post04-07-2021 10:40 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
What did you do to the socket to fix it? Im having the same problem but with the front right bulb.
Steelers8
Report this Post04-07-2021 11:03 PM Click Here to See the Profile for Steelers8Send a Private Message to Steelers8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I changed it. Everything looked good and I changed it anyway and works now. I found a lot or corrosion under the rubber boot that you couldn’t see so that was the problem. My directional was lit up on the dash so if that is what you have I am sure it is the same thing.
KCBSR
