  Need pictures of connector location
Need pictures of connector location by lyleap-gmc
Started on: 04-03-2021 06:32 PM
Replies: 2 (623 views)
Last post by: Notorio on 04-05-2021 08:09 PM
lyleap-gmc
Report this Post04-03-2021 06:32 PM Click Here to See the Profile for lyleap-gmcSend a Private Message to lyleap-gmcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an '84. I am putting a V6 in it. I know, not very exciting compared to some of the other swaps that have been done.
I would like to see some pictures of the wiring locations particularly the area behind the battery where the connector is mounted. Apparently, I need to relocate the C500 to the side from its current location in the center of the firewall. Seems like a good idea with the proximity of the V6 engine heat to the current location of the connector.
Many Thanks
Lyle
Notorio
Report this Post04-05-2021 08:06 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
It might help to post a picture of what you have now that you think needs to be relocated. There must be some existing posts in the Archives with lots of pictures for the 4-cylinder to 6-cylinder swap.
Notorio
Report this Post04-05-2021 08:09 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notorio
Member since Oct 2003
OK, took a quick search. Just the current Active Technical Discussion forum has quite a few threads. Check this one out from 2013: Irom Duke to 86 2.8 Swap
