  Grounding new Flasher unit, where can I ground it?
Grounding new Flasher unit, where can I ground it? by CZSeventyFive
Started on: 04-03-2021 04:12 PM
Replies: 8 (194 views)
Last post by: tlj_82 on 04-04-2021 08:11 PM
CZSeventyFive
Report this Post04-03-2021 04:12 PM Click Here to See the Profile for CZSeventyFiveSend a Private Message to CZSeventyFiveEdit/Delete MessageReply w/QuoteDirect Link to This Post
85 GT. Got an NSL Performance taillight LED kit, and for the included flasher unit there's a ground wire. My question is, where could I ground it? The wire is a bit short but I know I could extend it, but I'm not super positive as to where I can ground it under the steering. There's a couple spots I could maybe drill a hole, not sure if they're right and not sure if there's an existing screw I can tighten the fork under.
God forbid, I could just add an extension and use electrical tape to latch it onto something. There's a lot of plastic under here though, not a lot of metal. Wondering what my options could be.
Thanks
[This message has been edited by CZSeventyFive (edited 04-03-2021).]
dremu
Report this Post04-03-2021 09:51 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
The studs for the steering column should do the trick. Might have to cut off that spade and crimp on a larger one.
Also, please tell me you're going to remove that red rubber nub from the courtesy lamp on the fusebox. That's gonna melt.
-- A
[This message has been edited by dremu (edited 04-03-2021).]
skywurz
Report this Post04-03-2021 09:56 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to suggest this too... Just didn't feel like editing a photo
dremu
Report this Post04-03-2021 10:30 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picture can be worth a kiloword, easier than saying "the nut on the stud in the upper right sort of center of the screen" =))
-- A
CZSeventyFive
Report this Post04-04-2021 10:39 AM Click Here to See the Profile for CZSeventyFiveSend a Private Message to CZSeventyFiveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah okay, I did think about it but wasnt sure if that spot was grounded. I have more forks so cool, thanks man. I'll put it there.
Also yah, the light is from the previous owner, it doesn't actually seem to be paint, and it's not a rubber nub. Some kind of coating. I knew it glowed red down below but this was the first time I noticed that they coated the bulb. He painted red over the one of the interior lights too for some reason, lol.
IMSA GT
Total ratings: 250
Report this Post04-04-2021 11:42 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by CZSeventyFive:
......it doesn't actually seem to be paint, and it's not a rubber nub. Some kind of coating.
It's WAS a cover, now it's melted to be a part of the bulb
dremu
Report this Post04-04-2021 12:38 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Presumably wanted pimpy colored interior lights. Were it me, I'd replace it with a regular 194 bulb, which is the same size but less power (= cooler) than a 168.
-- A
CZSeventyFive
Report this Post04-04-2021 03:01 PM Click Here to See the Profile for CZSeventyFiveSend a Private Message to CZSeventyFiveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, probably past worrying about then until I get to the interior at large. Admittedly it has a nice outrun vibe, but it won't stay.
tlj_82
Report this Post04-04-2021 08:11 PM Click Here to See the Profile for tlj_82Send a Private Message to tlj_82Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sssesssssssssssssssssiit
