GM starters w/ 2 vertical bolts need special bolts made for this job. Do Not substitute.
Bolts have "self locking" features to prevent bolts and starter from dropping on highway.
3 different length. Many use 1 short and 1 long. Other use 2 medium or 2 long, etc.
Example:
https://www.dormanproducts.com/p-15719-45640.aspxClick picture to "zoom" to see way different bolt.
Other bolts may say are "starter bolts" aren't for most GM cars.
Hardware and holes must be clean and dry and proper torque.
If engine is aluminum block look up torque table for that engine, not Fiero engines.
Likely need starter shims too.
See my Cave,
StarterIf use a ½ shim... file or hammer cut end to thin that area so parts doesn't have point stress.
