| | | quote | Originally posted by thesameguy:
Yep.... there is a fuel distributor called Propel that sells E85 and biodiesel out of most Shell stations. I use the latter frequently! |
There's your ticket. By increasing the plenum volume and reducing runner length you will slow down air velocity if you don't change the shape of those straw-like shortened runners to make up for that lost air speed.
This reduction in velocity will affect fuel mixture resulting in eccess emissions compared to the stock plenum.You'll get that bit of extra RPMS at the expense of generous amount of remaning unburt mixture.
Now, to compensate you can mix an elixir of pump gas/E85 which will add oxigen to the mixture making it more homogenious. How much more? That's for you to find out through testing with an AFR meter.
If you pay attention to the shape of the runners of my intake, they vary in size at the top and at the bottom. This discrepancy in size gives me the best of both worlds, big torque at low RPMs and high HP at top end with the matching cam and head work of course. Specifically from 2500 to 4700RPM 300+WTQ and 300+WHP @ 6000RPM on a 3.4L NA.
My advice to you is to get the configuration that you want and enjoy your project with the limitations your local laws put on your vehicle. Wish you the best luck.
