  F23 - Mock up question
F23 - Mock up question by cam-a-lot
Started on: 02-09-2021 08:53 PM
Replies: 4 (623 views)
Last post by: Raydar on 04-06-2021 08:33 AM
cam-a-lot
Total ratings: 97
Report this Post02-09-2021 08:53 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello folks
I would like to get an F23 to replace my Getrag on my 3800 SC motor. My car is an 88
Will likely hold my breath and order WCF mounts, since nobody else seems to be making them, and will also grab an FY1 trans for the better gear ratio
Would like to do a mockup/ test fit before taking my car off the road, but it is hard to find a usable 88 cradle around here
My question is, would an 84-87 cradle work fine for mounting the F23 to test out fit, mounts, brackets? Is it necessary to also install axles for a test fit, or can I just use the cradle with existing Fiero trans mounts to test the bracket.
Or is it safer to try and find an 88 cradle to do this?
thanks
ericjon262
Report this Post02-09-2021 10:03 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
From what I remember, all chassis use the same engine and trans mounts, but, the toe link mount on the 84-87 overhangs the rear trans mount, on an 88, this overhang isn't there. That overhang also prevents Thelin's rear transmission mount from fitting an 84-87 without cutting the car, or the mount. Personally, I would hold out for an 88 cradle and know that everything is exactly like it should be.
cognita semper
Trinten
Report this Post02-11-2021 10:22 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my F23 swap we didn't need to cut the car (to my recollection). There was some clearance done on the passenger side frame rail, but I think that was more for plumbing clearance, not because of the transmission mounts. This was in an '86. It was also bolted up to a SBC, I don't think it changed things, it was using the stock Fiero axles.
My build thread has a bunch of pictures, measurements and info, thanks to FieroGuru (before he worked on it, pictures are gone because of the service they were hosted on is long gone, sadly).
cam-a-lot
Total ratings: 97
Report this Post04-03-2021 08:29 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
good info, thanks
My stuff from WCF arrived, looks to be good quality. Unfortunately they forgot to amend the shipping invoice to make it more reasonable, so I got killed by almost $300 in BS charges from UPS. My god... but the parts are here, look good. Will post pictures once things come together
Total ratings: 463
Report this Post04-06-2021 08:33 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cam-a-lot:
...Unfortunately they forgot to amend the shipping invoice to make it more reasonable, so I got killed by almost $300 in BS charges from UPS.
Heh... Imagine my surprise.
