How do you disassemble the clamshell that protects wires thru the firewall? Do you use heat? Do you boil it? thanks jon
------------------ Astronomy says we will find a coded signal from outer space. Then we'll KNOW that life exists there, for coded signals aren't by chance.
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
Some wires are wrapped around the internal clip, so not all wires can simply be pulled out.
I've taken a couple of Fiero ones apart, as well as similar parts for a couple of Caddy harnesses. IIRC, in the ones I've taken apart, there was only one wire wrapped around one tine of the "organizer", I @$$ume to hold it in place while they're potting it.
Their "bulkhead" pass through parts. Is, more likely Was, a GM "Packard" part label w/ PED somewhere and later made by Delphi Spinoff now called Aptiv own by BorgWarner Inc. in the UK.
Delphi.com Won't sell to you and finding a dealer w/ this exact part is unlikely and if you find one that works is often expensive.
GM dealers often can't get these then or now except buying complete harnesses.
Most other E-parts don't numbers too. Many OE plugs etc only have PED on them thru 1990's. PED is Packard Electric Division of Old GM before spinoff all parts to Delphi.
You and Dealers can't get many plugs etc even thru GM. Some parts are sold thru Dorman and other 3rd parties but often only common parts used by many models like Green MAP plug loose or as a Pig Tail "kit."
Ballenger motorsports, EFI connection, Waytek, Mouser and dozens of other retailers sell the pins, shells, and seals. I use all new stuff when I make a harness.
------------------ "I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262: Ballenger motorsports, EFI connection, Waytek, Mouser and dozens of other retailers sell the pins, shells, and seals. I use all new stuff when I make a harness.
Yes, C500 and other Pins are easy find and tools to make/handle them too. Some Shells are "Standard" and available. Some Shells and other parts was never available to the public and many others not even for GM dealer service and no GM/PED/Delpni # published.
Delphi even put out big catalog in a Public PDF years ago but often didn't have many GM shells etc.
So might find a 3rd party w/ X part but often can't search w/ GM and other "universal" PN.
How do you get that clamshell back thru the firewall? i had some trouble getting the clamshell back together until i realized that the rear slides together the front snaps. But i am having a bear of a time getting the rear clip on the clamshell. Any tricks?
The black side hooks in while the grey side clips in. You have to put it in cockeyed to get the black side to hook, then rotate it into the correct orientation to get the grey side to clip in. Then you can install the retainer.
