| quote | Originally posted by swing69: It makes sense to: 1) remove the spring and arm to compress the piston with a C clamp, as the center screw will just rotate freely....and when you align the piston, the screw/flats for the arm will be aligned. 2) IF just compressing the piston, it better rotate in if the arm is still attached 3) keep it all together and use the pin / block tool to rotate the piston back down into its bore, stopping in the properly clocked position.
Here' the video: I spoke with the maker (about other things....and he's a really good guy) I"m not slamming him at all, just trying to understand what is happening before I try to do the job....
Starts in at the 13 minute mark: https://www.youtube.com/wat...nel=LostNotForgotton |
I don't care if "he's a really good guy." Video between 13:40 to 14:30 shows only incompetence and
What Not To Do. Again, Piston rotates while C-clamping
then Something Is Wrong. This time more so...
It that Video:
1. Did
Not remove P-brake lever and nut.
2. Did
Not protect the P-brake screw.
3. Very Likely he wreck the pistons and/or P-brake screw or it's bearing "washer" doing this even if they weren't "dead" to start.
4. Many rear Pistons have "died" and blown out the back cover and "fake" retraction using a C-clamp w/ force applied by people w/o a clue.
5. Maybe even damage the caliper shell.
Big C-clamp can Destroy the Piston when used, more like Abuse, in the video above. And that's w/ or w/o # 4 "faking" retraction.
Shorter Terms... If pistons won't easily retract even following Cave directions, The piston and P-brake screw have Major Problems and are "Dead" even if seems to work before started a "brake job."
C-clamp method as shown in my Cave
Does Not Need Force to Tighten! I never even use even moderate effort to tighten the clamp in 30+ years of brake work for Fiero and other GM cars w/ same rear Piston setup. IOW When piston needs more then Finger Tip effort to tighten a C-clamp I except to have piston problems and likely won't self-adjust after whatever is done like Pad Replacement.
And before you asked, GM tool is likely going to have problems w/ "dead" pistons too. Or Twist Tools may seem to retract but Piston won't Self-adjust after job is done because inner and outer pistons are full of rust etc. (See my Cave,
Rear Piston notes)
