  Cradle bushing replacement... (Page 1)
Cradle bushing replacement... by CSM842M4
Started on: 11-05-2020 05:20 PM
Replies: 63 (2056 views)
Last post by: hunter29 on 06-27-2024 08:39 PM
CSM842M4
Report this Post11-05-2020 05:20 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, the "new" '86 SE went to get an alignment yesterday. Today the mechanic calls to tell me it's all ready, but that the subframe bushings are done. I think I can do it myself, but the Chilton's says to loosen or remove engine mount and numerous other bolts and remove the lateral links in order to drop the cradle. The mechanic, a fellow Fiero owner, says he just loosened the rear bolts, dropped the front end and pushed the bushings out and in. I'm ordering the poly bushings from TFS, which is a four-corner set. I guess what I'm wondering is, 1. Can I do this in my garage without a gantry to lift the body or a support for the engine? 2. If I drop one end at a time, with the 2.5 engine, is there room to do this? Any experiences/tales of woe with this project, please chime in! Thznks in advance - Chris
CSM842M4
Report this Post11-05-2020 05:55 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Quick update - just drove back from the mechanic. Wow. Car wiggles around randomly at city street speeds, gets pretty squirrely on the highway. Seems to happen most when adding throttle. Do this sound like cradle bushings?
Blacktree
Total ratings: 350
Report this Post11-05-2020 06:12 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a lot of things. But the mechanic should have noticed if something else was wrong. You have to jack up the rear of the car to replace the cradle bushings. While you're doing that, you can check if anything else is loose in the suspension.
The cradle bushing swap can be done at home, with a pair of jackstands and a floor jack. Put the rear end on the jackstands, and use the floor jack to lower and raise the cradle. The back of the cradle should hinge down with no issue. But to lower the front of the cradle, you'll need to loosen the rear cradle bolts a little bit, to make some slack. Just be mindful of any hoses and cables that might get stretched or pinched in the process.
That said, those bushings can be stubborn. You may be in for a fight. Laying under the car will make it more of a hassle.
[This message has been edited by Blacktree (edited 11-05-2020).]
CSM842M4
Report this Post11-05-2020 06:20 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Blacktree. Mechanic said one of his fronts practically fell out, the other not so much. He also said a ball joint/control arm bushing press should do the trick. So I'll turn my air pressure regulator up to 11 and let 'er rip!...
Blacktree
Total ratings: 350
Report this Post11-05-2020 06:33 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine cradle is part of the rear suspension. When the cradle moves around, it brings the control arms along for the ride. So yeah, it can really mess with handling.
There is no beneficial effect from cradle movement. Any movement of the engine cradle is bad. That's why I always suggest solid cradle bushings. But urethane is the next best thing. It'll still be an improvement.
Report this Post11-05-2020 07:53 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been using poly cradle bushings with success. Big improvement but I would not suggest trying to replace those bushings while the cradle is still in the car. You can use an engine support bar to hold the powertrain in place without disconnecting a lot. On the four its not that hard to remove just the cradle. The exhaust needs to be removed, along with the tie rods and the lower pinch bolts for the rear knuckle. Then you disconnect the mounts, remove the cradle bolts and the cradle should drop down.
Report this Post11-06-2020 12:06 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cradle rubber may be bad... Iffy rear can also be crap engine/trans mounts and dogbone problems. More so w/ stick trans cars. They should be check/fix on top of cradle problems.
Replace cradle set is "easy" enough and don't need to pull the cradle....
But
Front Cradle and other bushings w/ metal outer shells often have rotten outer shells. Worse can be hard or impossible to see w/o playing w/ mirrors, picks, etc. Even then very hard to find damage where rotted inside whatever part.
Any part of Outer shell gone mean little or no compression to the rubber.
Is also a big problem trying to Install polly and some metal replacements because need a good outer shell saved from old rubber.
Removing rubber in front cradle... See my Cave, Bushings and likely Bump Steer and rest of section.
Cradle won't move to make "polly noise" problem but still needs some Sil Grease just to keep out water between shell/sleeve and polly. Polly won't compress to fit 100% of outer shell leaving voids to hold "water" and rot inside out.
Cradle bushings can be done in the car often w/o screwing up alignment.
First make sure all bolts can be removed. Rear bolt's "Captive Nuts" are every well known problems.
Do Front bushings First then rear.
Rubber have enough play to allow you to replace fronts 1 at a time then both rears w/ polly. Polly is more flexible but final tighten front bolts after installing all of them.
Metal fronts often need both front bolts loose or out to install them. leave front bolts loose to install rear w/ metal parts.
Report this Post11-06-2020 12:37 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
But
I sincerely doubt that you can easily remove the front cradle bushings while it stays attached to the car. You may be able to do it by dropping it down slightly but then what. We've always used heat to melt out the old rubber and reuse the sleeves for poly but they usually catch fire.
Report this Post11-06-2020 08:49 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only Fools burn the bushing out causing many Dangerous even Fatal Problems. If you prevent that, Burning the bushing also heats the shell and "frame" you want to save causing heavy heat cycling, removing any rust protection and often heat treating making them weak. Burn metal rust big time and fast and can't repaint front shell easy to stop this.
I can and have done them in the car following directions in my cave by only heating the middle sleeve to push or pull it out. Again, Bushings near bottom in "Shell Games." Rubber will not transfer core heating to the shell enough to matter.
Very easy w/ Pencil Tip propane torch blowing heat thru the sleeve like BernzOmatic UL2317 (just this often sells < $15) and similar. You don't need max heat output from the torch but many need heat guards/shields made of soup cans protecting brake lines etc. (Heating brake line above 212°F(100°C) can boil old wet fluid then need to bleed rear brakes.)
Many have bigger tips or have torch w/o fuel control only 100% on or off and doesn't work well for this job like BernzOmatic JT680 TS4000 or TS8000.
If a rubber sleeve/core is frozen to the bolt, directions to remove without cutting or heating are there too. But many id10t will post to do either or both to the bolt that wreck the frame and destroys hard to get Class 10.5 or harder bolts. Heating the frame or bolts to glow will screws up heat treating and make them weak. Most get sloppy cutting and cut the frame making stress risers at minimum.
If you open the sleeve and still stuck use PB Blaster etc in the opening let it work. You'll get a lot more "oil" actively working when open the sleeve first.
Picture shown there is stuck sleeve removed then pulled out by following above.
wftb
Report this Post11-06-2020 11:00 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
To get the rubber out I just use a drill with a 1/4" bit in it.Drill in between the shell and the rubber and it will just "walk" around the rubber and separate it from the shell. Clean it up with a rotary wire brush. Poly is a total waste of time get solid mounts. The 88's have solid mounts for a reason, you do not want any movement between the cradle and frame. I have a set of poly mounts I will give them to you for the price of the postage. And that is more than they are worth.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
Report this Post11-07-2020 01:39 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did try that but had problems and wasn't any faster at getting sleeve out by heating in cave method. Couldn't find wire brush to fit the hole at that time for a drill. Hole is too big for "Dremel" w/ most common attachment to clean when have a lot of leftover rubber. (Note: Many "Dremel" including some real Dremel can break w/ sideways loads from cutting wheels etc. Is mainly shaft bearing(s) that fail.)
Metal is "ideal" but polly works and cheap for most users.
Night/day diff w/ polly vs rubber cradle set and that's 20+ years ago when most Fieros still had descent cradle bushings.
Blacktree
Total ratings: 350
Report this Post11-07-2020 01:40 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre: I can and have done them in the car following directions in my cave by only heating the middle sleeve to push or pull it out. Again, Bushings near bottom in "Shell Games." Rubber will not transfer core heating to the shell enough to matter.
I agree with this. Removing the center sleeve will make your life easier. As Ogre explained, aim a torch through the center of the sleeve, until the rubber around the sleeve starts to melt. Then the sleeve will easily push out (it might even fly out with a "pop" after you get it started). With the metal sleeve removed, it will be much easier to work the rubber loose. So you won't need to burn it, and make a big mess.
Report this Post11-07-2020 04:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can see the center sleeve being removed easily but then you still have to heat the center rubber to get it out. If we burn it out we just set fire to the rubber and allow it to burn away. The cradle would need to get near red hot to destroy the strength of the metallurgy. Then we insert the poly mounts which we have had no problems with. If Fieros handled well with rubber they certainly should improve with the harder poly. Probably not as durable as solid metal mounts but we see no evidence of movement with the poly cradle bushings and the car handles well.
CSM842M4
Report this Post11-18-2020 03:00 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all for the replies and advice. The car is backed in the garage now, and I'm psyching myself up to get started. A couple of questions before I do:
1. My guess is I want to place jack stands under the unibody "frame" behind the rear of the subframe. Is this correct? And, do I need to support the body elsewhere, like in front of the front of the subframe? Does more equal merrier?
2. Should I remove either bolt from the doggone, or will leaving it connected help to prevent tearing up engine and transmission mounts?
I'm trying to think ahead whether any hoses, cables or wiring is likely to be in harm's way, and none leap to mind. I will keep eyes open, however... Thanks again for the encouragement and warnings. Further input is always welcome! - Chris
Report this Post11-19-2020 03:22 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you can loosen all bolts easy before worrying about front bushing.
Cradle...
Back bolts like to break the captive nut in frame.
Front bolts like to "weld" into the bushing core. See my Cave, Bushings
Dogbone etc doesn't need bolts remove most times. Might need loosening so dogbone can easy rotate or move a little.
CSM842M4
Report this Post11-19-2020 08:55 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, ogre. Read your thread on bushings, very informative and helpful. Got everything basting in penetrant/lubricant until my next opportunity to get intimate with the car, hopefully Monday. Really would like to make sure I've got enough supporting the car so I don't tear anything up while I'm heaving ho at the old bushings and their hardware,...
CSM842M4
Report this Post11-26-2020 10:11 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, things have progressed better than i would have thought! The front end of the cradle is almost down far enough for me to start attacking the bushings. The rear bolts even loosened up with hand tools, and only scared me a little bit that they were going to break. I'm almost anxious to see how the rest is going to go! Update maybe by Wednesday...
peterh
Report this Post11-27-2020 08:03 PM Click Here to See the Profile for peterhSend a Private Message to peterhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did this awhile ago, a pain to get the front bushings out, I used aluminum foil and wet rags to prevent problems.
Made a huge difference in handling.
Total ratings: 463
Report this Post11-27-2020 09:28 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another vote for drilling the bushing out. Especially the bushings at the front of the cradle.
Use a 1/8" bit, and drill around the inner sleeve. If you hold it just right, it will "walk" around the sleeve, and break the bond between the sleeve and the rubber.
Then do the same with the outer sleeve. Once you make a couple of revolutions, you should be able to push the rubber out, with ease.
(Be prepared to break at least one drill bit. It happens.)
Once you have the rubber out of the sleeve, use a flap wheel or similar to remove all the remnants of the rubber from the inside of the sleeve.
I will never use heat to remove a bushing again.
CSM842M4
Report this Post11-28-2020 04:25 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, peterh and Raydar. I had toyed with the idea of making a pilot for a hole saw that would allow me to use the inner sleeve of the bushing as a guide, and the hole saw would just clear the outer sleeve, core the rubber out and leave not much to clean up. Who knows, I may try it anyway, just because I can excuse playing on the lathes and milling machines at work as "skill development". Either way, it feels like I'm close on the fronts. I can't see the rears taking very long - may be done by NEXT days off! Update soon...
CSM842M4
Report this Post12-16-2020 01:52 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally! Got both front bushings without fire! I ended up making a custom pilot for a hole saw mandrel and using three hole saws ( the biggest was a 1-3/4") and various lubriCANs to get them cored out, and a cutoff wheel to remove excess rubber and inner sleeve from beyond the edges of the outer sleeves. And the drill bit trick through the inner rubber. And, lastly, a 2" wire wheel to clean the leftover rubber from the outers.
One question before I proceed - is it a good idea to use any lubricant on the poly bushings going in? I know they're not going to move once they're installed, so I guess I'm more concerned about helping to impede corrosion in the coming years. I don't have any silicone bushing grease, like I've seen included with sway bars that I've installed before. But I do have silicone dielectric grease. I just don't want to use anything that might attack the polyurethane...
peterh
Report this Post12-16-2020 06:20 PM Click Here to See the Profile for peterhSend a Private Message to peterhEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used the grease that came with the poly bushings. If you don't have that I would just use a good wheel bearing grease, unless someone objects.
CSM842M4
Report this Post12-16-2020 07:02 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, peterh. I ordered my bushings from TFS, who then sent them to me in the ProThane box. Without grease. A little research showed that wheel bearing grease, while not the optimal substitute, was a viable one. So, I figured since my dielectric grease has a silicone base, it might work...
CSM842M4
Report this Post12-16-2020 07:29 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
CSM842M4
Member since Mar 2016
Just ran into my first snag. As I was loosening everything up, while I thought the bolt through the left rear bushing was getting loose, it was actually tearing the threads from the plate. Ogre said in his bushing cave that these were a notorious problem area. I see now that theogre knows all, tells all, speaks truth. So, since these fasteners are a known issue, and I refuse to believe that anybody would discard an otherwise perfectly good car after running into it, what have we found as working remedies? I feel like I can hammer the cut-off bolt and threads out of the hole in the unibody and fish it out, cut and thread a heavy plate to replace the now-missing ones, and replace the bolt with a class million.9 unit. Thoughts? Am I dreaming, thinking all of this will work as planned? Is there a less-labor-intensive fix that is also field tested and proven? Any/all input...you know the rest. Thanks in advance - Chris
Report this Post12-16-2020 11:50 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
many cut a flap in frame to remove rear captive nut.
might get at that nut w/o cutting but may need to remove other things blocking access to see and work.
Spray w/ PB Blaster etc often will work but can take hours to days to soak in the threads.
Careful use of heat on the nut may work too but avoid heating other areas could melt or cause fire. pencil tip w/ low flame on the nut only.
Use search.
CSM842M4
Report this Post12-17-2020 08:07 AM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, ogre. I can turn the bolt and watch the female threads turn with it through one of the wheelwell liner retainer holes. This makes me feel like if I can't hammer it out, i may be able to drill or burr it out.
CSM842M4
Report this Post12-21-2020 10:41 AM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nearing the end of this project, finally. I'm going to cut a window in the left side box to work with the "witch hat" nut. Hopefully just one question remains. While cleaning the cradle ears and beginning to test fit the bushings, it seems that the stamped steel inserts in the bottom of the ears will not allow the lower bushing half to slide in. The opening in the insert is the same shape as the lower half, but is smaller overall. Does this insert get removed to accept the poly bushings?
CSM842M4
Report this Post12-21-2020 11:09 AM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
CSM842M4
Okay, maybe one more question - anybody who has windowed the box, is there an optimum size and placement to avoid weakening the back end of the car? I have a variety of sizes of hole saws and plan to weld the slug back in, but maybe not right away. And, I would like to cut the window only once.
Report this Post12-21-2020 11:18 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Preference here is to remove the rear fascia. Its not that hard. Its about a 30 minute job. After you remove the tail lights there are only screws and push fasteners to remove. With the fascia removed you can reach into the frame with a faucet wrench to hold the captive nuts while you unscrew the bolts. Unless the cut is welded back in place, I dislike cutting into the frame as it weakens it,
CSM842M4
Report this Post12-21-2020 01:19 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just now got the fascia removed. Not as bad a task as I had feared. Hopefully, I can get a faucet wrench on the nut AND have it turn loose.
Report this Post12-21-2020 04:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I read threads like this one, I'm ever so grateful that I had no problems loosening bolts during cradle drops on the three different Fieros that I've done this to. It almost makes up for the horrendous time I had drilling out broken exhaust manifold bolts (on the forward side) years ago!
CSM842M4
Report this Post12-21-2020 07:48 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Dennis and Patrick. Yeah, I was expecting the front bushings to be the pains in the heiney. Right now, I'm reminiscing about the day I finished the fronts. It's kinda weird how the right rear bolt just twisted out as easily as you could ask for, and the left side is being a complete turd.
CSM842M4
Report this Post12-21-2020 11:10 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
CSM842M4
Major success! After a little research, I was able to get what I thought were "inserts" out of the cradle "ears". Turns out they were part of the lower bushing halves. Then, with a little prying, I got the "cap" off of the left witch hat nut. Now I have the witch hat out of the car and the cut-off bolt out of the hat. All that's really left is to remove the cap, clean and paint everything and put the car back together. Might drive it before Christmas! Thanks for all the input and encouragement. Until next time,... - Chris
CSM842M4
Report this Post12-26-2020 04:38 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just by the way, I was looking at possible solutions to the "missing captive nut" problem and stumbled on Rodney Dickman's answer. Looks like a quality piece and it would get the job done. But, it looks like it requires cutting a window in the unibody structure (and subsequently welding the window closed), as well as drilling two more holes in the bottom of the same structure. I scratched my head for five or four minutes and may have come up with a solution that does NOT require any mutilation and, once installed, will largely behave like the originals, except for being captive inside the structure. I hope to have a working prototype in the next few weeks, so if you're doing cradle work, have encountered the "loose nut" issue, would rather not cut up your Fiero and can wait a bit to see how this works out,... I will update as soon as the bolt is tight and we drive the car.
CSM842M4
Report this Post05-11-2021 10:24 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
As promised so long ago, the witch hat nut replacement prototype is in place. The car has been driven a few times since installation, with no issues or ill effects noted. This might be an option for anyone who who encounters the same issue as I did with the captive nut. I might could be persuaded to build a side or a set if anyone else wants to give them a try...
hunter29
Report this Post06-02-2024 07:08 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Guys, I'm getting ready to do this but I am confused by this from theogre.
Do I need to save an outer shell to use with new Poly bushings ? and for the front I assume..
thanks
hunter29
Report this Post06-02-2024 08:51 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
hunter29
Member since Feb 2020
Also please, the Retainer / Cage Nut, is this secured inside the cradle ? If not how do you hold it to loosen and tighten the bolt ?
Thank You
Total ratings: 200
Report this Post06-02-2024 09:16 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Hunter, there's a lot of talk about not being able to do this with the cradle in the car, but it can be done and I'd suspect that this is how most people have to do it.
The REAR most bushings are the easiest to come out (so long as your cradle nut hasn't broken free). Just as an FYI, this is not something that is Fiero specific. Almost every GM car with a subframe has this issue. I remember replacing the rubber bushings on a 1981 Pontiac TransAm, and the cradle nut was also a concern. I've been lucky, never had a single cradle nut break free, but I hear this does happen, so just be prepared. Not much you can really do... other than try to find access to the top of the cradlebolt and spray as much PB-Blaster on it as possible. At the very least, when you start undoing the bolt, the lubricant will be on the trailing threads, which will make the rest of the removal a lot easier.
Anyway, the rear most bushings are the easiest... because the cradle simply pitches down and you can easily replace the bushings.
Keep in mind though, replacing the FORWARD bushings needs to be done FIRST, because if you've removed the rear bushings and replaced them, it's nearly impossible to get the cradle to lower in the front enough to get at them. So... you'll want to replace the front ones first.
I used poly, just because it didn't require anything to be pressed in, etc.
On the drivers side, I used a small blow torch to melt / burn out the rubber, but for the passenger side, I used a drill... it was too close to the fuel lines and I wasn't willing to take the risk. To be honest, you can do the entire thing with a drill. Just buy a bunch of drill bits, and you slowly drill around the bushing. When you've got most of it out. Honestly, you could probably use a hole-saw... but I did it in a parking lot when I was ~20, so I had basic hand tools. But if I had to do it now, and I didn't want to remove the cradle... I'd use a hole saw (smaller diameter not "just fits"). You don't want to damage the shell.
Anyway, I've done it with the cradle still in the car. It's not hard, it's just not something an old person wants to do... for sure. When I was 19/20 and had all the time in the world... yeah. But at 46, no eff'in way I'm going to get under that car to do that unless I have a nice air conditioned garage and tons of safety jacks to make sure I don't crush myself.
[This message has been edited by 82-T/A [At Work] (edited 06-02-2024).]
hunter29
Report this Post06-02-2024 10:16 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for that, I am beginning to understand how this will go down. I am unclear where I will put the jack stands, Will have to take a photo of what I think is the correct spot.
My car has 15k on it and was stored in a dry place for 29 years, I have never had rust problems and the threads of the front bolts are very clean so I hope I will get lucky with the rear.
Anyone else, I'll take all the advice I can get.
1985 Fiero GT
Report this Post06-02-2024 02:15 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Immediately in front of the front cradle bolts, you can see where the "frame" goes towards the front of the car, there's a flat section maybe a foot or so in front of the front cradle bushings, where a jackstands fits perfectly, that is where it is supposed to be hacked up by service garages, etc, but jackstands fit snuggly and securely, make sure you unbolt the dogbone. As for the rear cradle bolts, break them loose without a jack supporting the cradle, the extra downward tension will hold the captive nut in place, then clean the screw threads, start the bolts as far as possible by hand, then lower the cradle onto them and screw them in the rest of the way, once again using the cradles weight to hold those nuts in place. Mine broke free and came out fine with help from the weight of the cradle, then when I put them back in realised they were free spinning unless there was downwards pressure, using the weight of the cradle made them go in effortlessly.
