| quote | Originally posted by imacflier: The only cost I can see to this is increased pedal TRAVEL until the pads contact the rotors. |
Correct, the pedal will have to move further.
Actually, that's the greatest risk of this modification. If the pedal hits the floor before you're able to lock up the brakes, well then you'll never be able to do full emergency braking.
Normally there's supposed to be some "buffer zone"; extra travel beyond what is needed for lockup in case you get air in the system, or more squishiness for whatever reason.
I would not necessarily say automatically no to the modification (for a one-owner car), but you'll have to make sure that you have enough buffer zone. And it will be a smaller buffer zone than stock.
| quote | Originally posted by imacflier: better modulation prior to locking up the tires which is a very good thing.
I would say a more squishy brake pedal.
Whether that facilitates modulation is then up to the driver and his body.
For some, that makes modulation easier. The mountain bike crowd seems to like a soft brake lever.
Personally, I find brakes easier to use when they are firm.
| quote | Originally posted by imacflier: And has anyone actually TRIED it? |
Not me...
Voluntarily reducing the buffer zone isn't my cup of tea, neither is making the pedal more squishy.
| quote | Originally posted by imacflier: DECREASING the bore size will result in increased line pressure (and therefore clamping force) per pound of pedal pressure. |
That's correct, unless the pedal hits the floor.
[This message has been edited by pmbrunelle (edited 10-10-2020).]
