  R134 "Self Sealing can"?
R134 "Self Sealing can"? by Raydar
Started on: 09-07-2020 12:20 PM
Replies: 5 (517 views)
Last post by: KissMySSFiero on 09-10-2020 11:01 PM
Total ratings: 461
Report this Post09-07-2020 12:20 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay... What is a self-sealing can?
I'm looking for some R134 to top off my system.
Amazon sells this. Decent price, these days.
Link
The comments indicate that it uses a redesigned tap/adapter. My old adapter seals if you don't remove the adapter from the can.
Do I need to replace my adapter? I don't see any real difference, looking at pictures, unless the threads are different, or something.
jpeeler
Report this Post09-07-2020 01:08 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the new cans have like a rubber top vs the piercing style of the old cans. You can get an adapter for your tap. I got mine at Walmart as well as the R134 for about $5 a can.
[This message has been edited by jpeeler (edited 09-07-2020).]
Total ratings: 154
Report this Post09-07-2020 02:57 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steve, I tried to top off my truck using the old do it yourself gauge that I had always used with the R134a. When I punctured and retracted it to allow the refrigerant to flow, the can sealed itself and I got nothing. Either your piercing valve is plugging it or it self'-seals. I held the trigger down as I opened and closed the valve and I never got flow.
Report this Post09-07-2020 03:23 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"New" aerosol can is require by EPA after 2017 to stop dumping open cans to air. These are just 1 of the normal "Spray Can" types w/ a valve to open and shut when done.
Because w/o this No way to save open cans often even for a few days because most gauge sets etc have small leaks.
See A/C Pro® Self Sealing Valves https://www.youtube.com/watch?v=4tIQ9YPN81c
IOW They make adapters to fit new cans to old equipment or just get a new can tap.
Blue plastic adapter sold most anywhere for a few dollars.
https://www.amazon.com/Inte...dapter/dp/B004NL2XM0
New can tap example: InterDynamics Certified A/C Pro R-134a Can Tap PN: CERTDV134
https://www.amazon.com/Cert...an-Tap/dp/B07RMSK8W3
https://www.oreillyauto.com...ap/certdv134/6059666
Total ratings: 461
Report this Post09-07-2020 10:17 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone!
I searched for a few minutes and found pics of the old vs the new.
Think I've got it.
(Obviously, I'm behind the 8 ball here, since this happened in 2017. Doh!)
KissMySSFiero
Total ratings: 111
Report this Post09-10-2020 11:01 PM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently replaced my adapter with a new one. I don't know if it was different, but it didn't seal anymore. it seemed to not like the new types of seals and wouldn't let the reseal.
Why shop for freon on amazon? it's cheaper then that at my local walmart. I'm pretty sure all R134 is federally mandated to be the same formula. All of the extra freeze stuff sounds like a gimmick.
I've recently replaced the compressors(and other components) in 3 of our vehicles. It was $5-5.50 per 12oz can. I've done enough ac work to justify buying a 30lb can, but I haven't done it yet because the stuff stays so cheap for me. I'm in FL now, but SC was cheap too.
What are you doing that justifies 12 cans? Just curious.
SSFiero@Aol.com
