FIVE - 100% CUSTOM Fiero MODS! by DimeMachine
Started on : 08-08-2020 08:12 AM
Replies : 13 (579 views)
Last post by : timmer on 08-18-2020 12:00 AM
Aug 8th, 2020
DimeMachine Member Posts: 957 From: Eastern Metro, Minnesota, USA Registered: Sep 2011
I have had this Fiero for over a decade and it has grown with me.
Every nut and bolt has been touched at one point and along the way I have come up with 5 mods you won't see anywhere else.
Take a look and let me know your thoughts!
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
[This message has been edited by DimeMachine (edited 08-09-2020).]
08:12 AM
Warlordsix Member Posts: 159 From: Registered: Apr 2016
Thanks for sharing. Good stuff on your channel, BTW.
Ernie
------------------ '87 Fiero 4.9 5-speed
01:35 PM
Patrick Member Posts: 39005 From: Vancouver, British Columbia, Canada Registered: Apr 99
Your video editing is getting quite slick. Good job.
Now if you'd just learn how to
embed your videos within your posts.
[This message has been edited by Patrick (edited 08-08-2020).]
05:28 PM
Aug 9th, 2020
quote Originally posted by Patrick: Your video editing is getting quite slick. Good job. Now if you'd just learn how to embed your videos within your posts.
Thanks for the compliment and the suggestion. I did about 10 mins of searching and I could not figure out how to embed so the video plays in PFF.
If you have a link that shows how to do it I would like to start doing that.
Thanks,
Dime.
11:15 AM
Gall757 Member Posts: 10938 From: Holland, MI Registered: Jun 2010
[This message has been edited by Gall757 (edited 08-09-2020).]
12:16 PM
Notorio Member Posts: 3014 From: Temecula, CA Registered: Oct 2003
quote Originally posted by DimeMachine: Thanks for the compliment and the suggestion. I did about 10 mins of searching and I could not figure out how to embed so the video plays in PFF. If you have a link that shows how to do it I would like to start doing that. Thanks, Dime.
I'd like to learn that too
12:36 PM
IMSA GT Member Posts: 10700 From: California Registered: Aug 2007
[This message has been edited by IMSA GT (edited 08-09-2020).]
01:15 PM
This is what your post should look like. Add the "Youtube" brackets and paste the address of the video in between.
There seems to be an error when trying to embed your video. This is what happens. I don't know if it is a Youtube issue or an issue with your video being private.
01:35 PM
dremu Member Posts: 293 From: Livermore CA Registered: Feb 2019
You have to slightly edit the URL, like so:
which results in
-- A
[This message has been edited by dremu (edited 08-09-2020).]
02:17 PM
quote Originally posted by dremu: You have to slightly edit the URL, like so: -- A
I tried that but didn't remove enough of the url. I wonder why that happened. Every Youtube video posts just fine with a copy/paste except this one.
03:49 PM
quote Originally posted by IMSA GT: Every Youtube video posts just fine with a copy/paste except this one.
The mistake most people make is to try and use the brackets [youtube] [/youtube] around the URL supplied when SHARE is clicked below the video window at YouTube. That
doesn't work when trying to embed a video here.
You need to instead use the URL of the YouTube video up in your browser's address bar. And the easiest way I've found to get the
correct address (to use to embed a video here) is to copy the
name of the video and then run a search for it at YouTube. When you then click on the found video to open it, the URL in your browser's address bar is the one to use here.
That might sound complicated, but once you're aware of the process, it almost takes less time to do than to read this.
04:39 PM
quote Originally posted by dremu: You have to slightly edit the URL, like so: which results in -- A
BINGO!! Thanks to all that worked to educate me!
04:43 PM
Aug 12th, 2020
quote Originally posted by Warlordsix: Thanks for sharing. Good stuff on your channel, BTW. Ernie
Thank you for the feedback - I greatly appreciate it!
------------------ 84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
12:51 PM
Aug 18th, 2020
timmer Member Posts: 1266 From: langley/surrey b.c..canada Registered: Oct 2002
is there a how to ion the gauge mod ?
12:00 AM
