  Fuel rail Schrader valve leaking
Fuel rail Schrader valve leaking by cvxjet
Started on: 08-02-2020 08:05 PM
Replies: 3 (666 views)
Last post by: css9450 on 08-03-2020 03:30 PM
cvxjet
Report this Post08-02-2020 08:05 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
A fellow Fiero-er stopped by to do some work on his car...When he arrived there was a very strong gasoline smell....started checking and found that fuel was welling up out of the fuel Rail schrader valve......(No cap)
I tried to tighten it but still leaking, so I took the cap from my car and screwed it on, which stopped the leak so he could drive back home (75 miles)
Questions; 1) Schrader valve; What is the part number and where would it be available?
2) Where can I get him(Or me) a new cap- are they A) available for purchase or B) what other cars use the same cap?
Any help would be appreciated!
Report this Post08-02-2020 10:13 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC the stem in that valve housing is a common replacement part. Its been a long time since I fooled with one but IIRC it was the same size as the ones used on the A/C ports. Removal requires a special tool. Remove the valve and head down to a full line auto store for a replacement.
cvxjet
Report this Post08-03-2020 02:38 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dennis....But what about that cap? Are there other cars that use the same CAP? (There are no Fieros around here in the JYs at the moment)
css9450
Total ratings: 86
Report this Post08-03-2020 03:30 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just grab one from any pretty much any other car in the junkyard. The threads on a Schrader valve haven't changed since dinosaurs roamed the earth. Most newer cars have plastic caps.
I wouldn't take one from a tire though.... Who knows, it might melt. Get one from a fuel rail.
