  EGR Valve Recommedations
EGR Valve Recommedations by J.E. Rowlett
Started on: 07-20-2020 12:59 PM
Replies: 2 (412 views)
Last post by: J.E. Rowlett on 07-21-2020 08:43 AM
J.E. Rowlett
Report this Post07-20-2020 12:59 PM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 GT V-6 / Need a new EGR Valve, any recommendations??
Report this Post07-20-2020 05:31 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the vacuum nipples on the valves aren't in the same position as our OEM valves. You might have to add a rubber hose to your hard plastic line to get it to connect. O'Rielly Auto Parts sells a Standard Ignition valve that has the nipple in the right position.
Some of the valves also have a top that can be rotated to position the nipple in any position. Personally, I don't see how it could have an effective seal with that feature.
J.E. Rowlett
Report this Post07-21-2020 08:43 AM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, I'll check it out.
