Derlin "pucks"/dowels/pins
Are Not the "best." Far from it.
See 2nd Gen Headlight Pin Replacement
https://www.fiero.nl/forum/Forum2/HTML/128600.htmlRubber hose "pucks" are not very good but likely won't wreck the gear or output shaft like Delrin and other hard materials.
You Do Not need to remove the motor to remove the gear for Fiero P-side motor w/ output shaft exiting thru removable cover. (D-side on other cars.)
Just careful force it out. Help if you file 3-4 "teeth" in the rim to get back in. Doesn'y even need full teeth. 1-2 near full and 2 maybe half depth just so motor slips over the rim.
Too hot to dig thru old parts. Can see an example in
https://www.fiero.nl/forum/F...HTML/128600.html#p15 at top next to rotation arrows. But do it away from from "puck" areas.
Filing the rim is the least of issues and if gears breaks and won't be this is why.
Removing motor often has more problem than just compressing brush springs or dealing w/ BB on the bottom.
Removing or adjusting the "BB End" wrong causes problems too. That bearing and others Hates preloading and will cause failure sooner or later if preloaded or too loose. Wrong lube there can do same.
You can get New Gen2 motors from Cardone and others. Many sold for less $ on Ebay etc but little to no warranty.
New Cardone units in my car is even faster then OE a little bit. Opens HL ~ ⅔ of 1 sec.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 07-19-2020).]
