  Alternator Bracket
Alternator Bracket by steve308
Started on: 07-04-2020 06:05 PM
Replies: 7 (586 views)
Last post by: steve308 on 07-10-2020 08:40 PM
steve308
Total ratings: 58
Report this Post07-04-2020 06:05 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone direct me to a clear picture and or removal tutorial for the alternator bracket on a V6 (1986). I've removed every nut, bolt and wire. Alternator is loose but the bracket is blocking it from moving it to a hopefully removal area. I've removed both the upper and lower bolt from the bracket that I can see...is there a third bolt hidden? And yes the bracket snapped but I have a Rodney repair bracket brace on hand.
Happy 4th of July to all!
fierosound
Total ratings: 286
Report this Post07-04-2020 06:34 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's 4 bolts (3 to head, 1 to block)
[This message has been edited by fierosound (edited 07-04-2020).]
steve308
Total ratings: 58
Report this Post07-04-2020 07:25 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. Looks like kidney stones will be kicked to number 2 on the list of things I hate.
Report this Post07-04-2020 09:03 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
One extra tip. If your alternator bracket is corroded it can break easily. The Fiero Store sells a replacement that is a bit stronger than the original. You may or may not need it but it is available.
Dave E Bouy
Report this Post07-04-2020 09:15 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
LMAO
steve308
Total ratings: 58
Report this Post07-04-2020 10:21 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep..It snapped. I have the Rodney bracket metal plate gizmo so hopefully I can cobble it back together.
Report this Post07-08-2020 04:10 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's fairly typical. That bracket was not made very strong and years of flexing and corrosion can set in. The Rodney part is an Alternator Bracket Reinforcement Plate. If your alternator bracket has snapped the plate may not work. You probably need the new bracket that the Fiero store can supply. Good luck replacing the alternator. in an auto Fiero it is not a pleasant job, but you know this already.
steve308
Total ratings: 58
Report this Post07-10-2020 08:40 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Now that the feeling has returned to my finger’s wrist and arms, I am happy to report that the alternator is installed and functioning. Thanks to all who contributed suggestions via the tech page and by PM. A special thanks goes out to a fellow FIERO owner and friend, Pat Jones, who came down on day two to wrestle the old one out and fight the new one into position. Friends helping out are what make putting up with these cars worth it. I also want to note that the Rodney Dickman alternator reinforcement bracket saved the day as the bracket did break when the original alternator was unbolted. (I also installed Rodney’s idler, another well engineered item).
Steve
