  What Size Are The Danged Rubber-Covered Torx Sheet Metal Screws on the Door
What Size Are The Danged Rubber-Covered Torx Sheet Metal Screws on the Door by imacflier
Started on: 06-20-2020 08:00 PM
Replies: 3 (719 views)
Last post by: imacflier on 06-21-2020 05:11 AM
imacflier
Report this Post06-20-2020 08:00 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good Evening, All,
I am going to have to remove the door skins on my '88 GT to do some work on the windows.
I know there are several rubber covered torx sheet metal screws on the leading edge of the doors.
I will be blessed if I can find these screws in the 22p, And TFS has none, and they have been discontinued.
Since I must work in my driveway I want to minimize the time I have to cover the naked doors, so I want to order stainless button head sheet metal screws BEFORE I begin disassembly.
Does anyone know the size and length of those blasted screws???
Please?
TIA,
Larry
Report this Post06-20-2020 08:12 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ones on front and back of the door skins?
T30.
And is a bolt not sheet metal or other self threading.
Problem is many a stuck/frozen to the "nut" from rust.
Might be able to snake a spray tube under the plastic and use BP baster etc. and wait for it work work. Expect hours to days to wick in and work.
fierosound
Total ratings: 287
Report this Post06-20-2020 08:57 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removing door skins:
https://www.fiero.nl/forum/Forum9/HTML/000019.html
Door skin screws are GM part number:
20375022 - SCREW W/NYLON CAP M6 X 1 X11.5
Door skin screws - Kit P007 - $10 for pkg of 7
http://www.ponyent.com/databases/fierolist_01.pdf
Only other listing I COULD FIND was
https://www.ebay.com/itm/7-...-Fiero-/133271205187
[This message has been edited by fierosound (edited 06-21-2020).]
imacflier
Report this Post06-21-2020 05:11 AM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOW!
Thanks ever so much, Guys! I am truly surprised that they are machine screws!
Those will be much easier to source as stainless button head cap screws, too. (I always replace my hardware with that type of fastener when I can!) I have had very good luck with fastenere.com, BTW.
Anyway, thanks to all!
And warm regards,
Larry
