High speed blower runs direct "12v" via a relay from Fusible link A.
ONLY Low speeds use the resistor pack.
You have to rewire the car and maybe the PWM "box" to make it work.
Blower low speeds has 20a or 25a fuse so should have 25a PWM control minimum. (20a heat only, 25a heat/ac.)
PWM handles 25a or more likely will need air to cool a heatsink. Little or No air = short life to your "upgrade."
Other cars have Mosfets or Transistors that are in Heater/AC box for same reason as resistor pack.
Blower may only use 10a but having PWM w/ higher amp rating means MOSFET should run cooler.
Plus OE Switch is on thin wire that eats power to the motor vs purple wire to run high speed.
Get FSM etc and See my Cave,
Wire ReadingResistor pack sets lowest speeds so AC won't freeze up blocking air flow at minimum. That might even cause AC system problems killing the compressor etc.
Blower w/o enough power will burn out too. Example: You turn down PWM speed after running higher speed may run "ok" but forget then start the car hours to weeks at lower speed won't start the blower is where you fry it.
IOW "continuously variable blower speed" 0 - 100% isn't a great thing for many motors and why likely have to rewire the PWM "box." (Is not like a train set etc where is easy to see a motor not turning.)
Some could likely PWM the blower but is not a simple PnP w/ any "standard" module.
Quick example: A small Arduino could PWM the low speeds using same OE switch etc. Can mount the MOSFET in the ac/heat box likely using same wires and board.
While not continuously, That allow you to adjust each low speeds of a given setting of the OE control switch. When on high runs blower on OE relay.
Blower likely need a "flyback" diode or whatever to protect the MOSFET.
Later Resistor packs have screens and thermal fuses to prevent fires. Google them and use image pages to see many types.
Is mainly a fire problem now for most people because has decades to suck in leaves etc. Or stored for months for mice to live there.
