This Only Matters to people that think they can run E85 on cars
without Flex Fuel equipment. (Some areas have E15 also made to work in Flex Fuel vehicle only.)
W/o Flex Fuel sensor(s)...
Every time you change % of Ethanol for any reason like you just drive to anyplace w/o E85 pumps and need gas then that ECM/PCM will need reprogramming to run the engine right. More so w/ DIS and related because can't even adjust Base Ignition timing like Distributor engines like HEI etc.
"E85" has less Ethanol then advertise is no surprise to many. Often same reason "Normal" pumps w/ 10% Ethanol labels are often wrong. Depending on Summer/Winter mix at the "Local" bulk fuel distributor and just where you are can change the gas formula and amount of Ethanol added to meet USEPA and states rules of gas used in an area.
Even when you buy fuel only at 1 station, the %E can and often will change. Very likely Winter "E85" fuel often needs less Ethanol so more vehicles will Start reliable in cold weather. Depending on Ethanol availability at a given time may change %E for Summer "E85" fuel or even from batch to batch delivered by local tank truck at any time of year.
So More accurate is "normal" pump saying "Up To 10% Ethanol" because many places have much less Ethanol at different times of year. E15 or E85 should be label the same but creates a huge problems for stations and 99+% of buyers that have no clue and don't care.
Ethanol is added at the "last mile" distributor then ship to your local station by tank truck because Ethanol Cannot be put thru nation wide oil/gas pipeline system. At minimum... If/When their E tanks are low, they must make sure they have enough to keep "E10" flowing out to the stations to meet EPA/state rules and if needed "F" the E15 and E85 users because was made to use in Flex Fuel equipment
and the vehicles w/ it don't care.Note that gas is same for all stations in most areas but whatever additives for cleaning at Texaco etc are added at same "Local" distributor before loading on a tank truck or even at the time of delivery for whatever brand of gas. ("Last Mile" "Local" distributor can be 50-100 miles away maybe more from your local station.)
