  No crank if steering wheel is in the up position
No crank if steering wheel is in the up position by unplugged1981
Started on: 05-07-2020 03:11 PM
Replies: 6 (197 views)
Last post by: unplugged1981 on 05-15-2020 03:01 PM
unplugged1981
Report this Post05-07-2020 03:11 PM Click Here to See the Profile for unplugged1981Send a Private Message to unplugged1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello Forum!, a couple of months ago I had a no crank no start issue.
So I replace the starter,
-cleaned all ground connections,
-fully charged the battery (my battery is dated from 2016)
-Air filter is ok
-tested spark from the spark plugs, its ok.
-checked the Fuel pump, its ok
-New ignition coil
-New Distributor
My car now cranks (but wont start) but only if I tilt the steering wheel down, if I tilt the steering wheel up it wont crank or start. Is this something related with the ignition switch. What must I do?
Any help would be greatly appreciated.
Thanks in Adv.
FX
Report this Post05-07-2020 05:04 PM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the actual switch is down low on the steering column. and operated with a cable from the key. It may be out of adjustment. If so, the switch may have a slotted mount to slide it up, or down to adjust...
unplugged1981
Report this Post05-07-2020 07:32 PM Click Here to See the Profile for unplugged1981Send a Private Message to unplugged1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ill go check and see if it needs adjustment. Something I forgot to mention. This whole thing started while I was driving back home and all of a sudden the car stalled and that was it, It wouldn't start again.
Can the car stall while driving due to a broken faulty ignition switch?
thanks
FX
Report this Post05-10-2020 02:58 PM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
...Of course...Check slide adjustment first...
Report this Post05-10-2020 07:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely Link parts between lock and switch are bad.
And/or tilt mech mounting bolts are loose.
Adjusting switch might hind this for awhile.
See my Cave, Steering
[This message has been edited by theogre (edited 05-10-2020).]
seq
Report this Post05-11-2020 01:17 AM Click Here to See the Profile for seqSend a Private Message to seqEdit/Delete MessageReply w/QuoteDirect Link to This Post
This affected me, where my steering wheel was loose enough to actually turn the car off while driving. unplugged1981, if your column is loose, you should definitely fix that first.
Seq
1987 Fiero GT : Information | Gallery
NOTE: If you re-host any of my images on PIP, send me the Image URL and link to this post, and I'll update it.
unplugged1981
Report this Post05-15-2020 03:01 PM Click Here to See the Profile for unplugged1981Send a Private Message to unplugged1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ogre, fx , seq, thanks for the reply and info . My steering column is well fixed I don’t have any kind of movement but one thing to mention is that a few years ago I changed the whole steering column. Anyhow I’ll Order a new ignition switch but I guess I’ll have to wait a bit because right now all shipments are slow due to the pandemic.
