  Getrag shift cables placement
Getrag shift cables placement by Backtothe80s
Started on: 04-22-2020 05:22 PM
Replies: 14 (387 views)
Last post by: gregr75 on 12-26-2023 06:07 AM
Backtothe80s
Report this Post04-22-2020 05:22 PM Click Here to See the Profile for Backtothe80sSend a Private Message to Backtothe80sEdit/Delete MessageReply w/QuoteDirect Link to This Post
This maybe a dumb question but it’s been 13 months since I started the removal and rebuild of my cradle and v6 engine. Placed it back in yesterday but I’m stumped on how one of the Getrag shift cables are placed. I know the select cable runs along the fire wall and under to the bracket on the transmission as this can be seen in some pictures online and the manual. The one I’m puzzled with is the shift cable. Does it run over the exhaust cross over pipe? I would find this an odd set up being so close to the exhaust and for the life of me I can’t remember how it was placed. Any picture(S) would help or any suggestions on how’s it’s placed. Thank you in advance.
Report this Post04-22-2020 05:32 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Gall757 (edited 04-22-2020).]
Backtothe80s
Report this Post04-22-2020 05:40 PM Click Here to See the Profile for Backtothe80sSend a Private Message to Backtothe80sEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you I happen to have this in the factory manual as well. Problem is it doesn’t show how it’s placed at the engine. If you see my photo the cable sits right on the exhaust? Doesn’t seem correct to me.
Report this Post04-22-2020 05:54 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The EGR vacuum line is extra long and in the way, but I think the select cable should be on the other side of the exhaust. 88 Y pipes had that extra heat shield, so it's going to be close.
Backtothe80s
Report this Post04-22-2020 06:41 PM Click Here to See the Profile for Backtothe80sSend a Private Message to Backtothe80sEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, too funny. I made all new vacuum lines and left this one long until everything was bolted in. I will have to cut it for sure. Ok so it does go in that direction. What an odd placement. Thank you again.
[This message has been edited by Backtothe80s (edited 04-22-2020).]
fierosound
Total ratings: 287
Report this Post04-22-2020 08:01 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It goes over the crossover pipe as you have it. I have an 87 with tin heat shielding above the crossover.
It is close but it is what it is. The shielding plus the wrap on the cables seems to do the job. (old pic)
[This message has been edited by fierosound (edited 04-23-2020).]
Total ratings: 237
Report this Post04-23-2020 11:14 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct, it goes right over the exhaust like that. That's what the heat sleeve is there for.
gregr75
Report this Post12-03-2023 04:38 PM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I'm trying to hook up my used Getrag select cable, after reinstalling the engine/trans into the car.
I believe i have the select cablr routing right according to service manual, above diagram, etc. but i cant seem to get the cable through the trans bracket (arrow) and select lever (arrow) similtaneously. the bracket and select lever seem to be misaligned with eachother. is there a trick to this?
Total ratings: 461
Report this Post12-03-2023 09:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the bracket on the transmission is bent. The cable should go through the hole in the bracket and make almost a straight shot to the select lever.
This is a later FWD tranny. Doesn't have a slave cylinder in the same place as yours.
[This message has been edited by Raydar (edited 12-03-2023).]
gregr75
Report this Post12-04-2023 06:41 AM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! I was wondering that after i posted this. Makes sense because i used this as a lifting lug when hoisting the engine out. Ill try bending it back to align with the lever.
Total ratings: 465
Report this Post12-04-2023 02:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Total ratings: 253
Report this Post12-04-2023 02:57 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
[This message has been edited by IMSA GT (edited 12-04-2023).]
Spadesluck
Report this Post12-04-2023 04:15 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doh, lol. Thats a lesson learned I suppose.
gregr75
Report this Post12-23-2023 07:58 PM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK so i bent the select cable bracket on the tranny back into alignment, well enough where it goes together. got a beautiful new r. dickman select cable. Going to first and second gear is easy, but going to fifth and reverse, while much better than before still could use some improvement. I read somewhere that cable routing helps a lot. i followed the meisners service bulletins but it didnt specify if the select cable travels over/under the coolant tubes.
In my pic i have the cable going under the 2 smaller coolant tubes (blue) but over the bigger coolant crossover tube (yellow). i also didnt use the hook on the left side of the pic intended for the select cable because it seemed like i didnt have enough length to grab it.
Wondering what other peoples select cable routing looks like?
gregr75
Report this Post12-26-2023 06:07 AM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump. can anyone comment on the select cable routing around the coolant/ac lines. over/under?
