So two of my fuel injectors are bad and I am just wondering about using the accel replacements ones, I have an 85 gt 2.8l. Do I stay with the 15lb ones or am I able to use 19lb ones?
you cnt go up to 19lb without burning a chip that adjusts the fuel BPW I believe. I have all 6 15lb originals I removed from my 40k car after doing the 3.4 swap. they worked perfectly. PM me if you want them for cheap. I olso have a bag of OEM new rubber oring seals for the ends of them as well
[This message has been edited by jjd2296 (edited 04-17-2020).]
I just bought a set of Bosch EV1 injectors for a 3.4. I'm not sure what brand are stock in the Fiero. I think they are Rochester but I couldn't find a 15 # injector in the Rochester brand.
I would suggest you take jjd2296's set, have them refurbished and flow matched. Injector Planet, Motorman Injectors or Injector Connection can do it for you and if there's an unrepairale problem with any of them, they can recommend the equivalent replacement set.
I haven't dealt with Motorman but the other two have given me good service.
[This message has been edited by fierofool (edited 04-17-2020).]
Monkeybean, I just paid $90 for a set of refurbished and flow matched Bosch injectors from Injector Planet. The other places like Fuel Injection Connection and Motorman Injectors have comparable prices. When they have been refurbished they usually are flow matched. It's worth having them serviced before installing them. And whether you've done it recently, or not, replace your fuel filter before installing them.
Didn't the 3.4s use 17lb injectors? Is everyone doing fine with the 15lb? I've got my 3.4 short block being inspected before I install it and I've been wondering about this...
The injectors for my 3.4 are rated at 17# which actually flow 16.76 at 43.5 psi, stock Fiero fuel pressure.
Bosch EV1 Fuel Injector Jetronic port / 4 hole nozzle
Flow rates @ 43.5 psi / 3 bar 16.76 lb per hour (My Note: 17# rated injectors flow at approximately 16.666 lb/hr at 3 bar or 43.5 psi. See calculator chart below) 126.5 G per min. (N-Heptane) 176.1 cc per min
15.90 Ohm resistance
Bosch Part # 0280150415 BMW part # 13641730060
CHART FROM MOTOR MAN FUEL INJECTOR SUPPLY
Fuel Injector Size Calculator Horsepower (at the flywheel) 160 Number of Injectors 6 B.S.F.C. *
I went with rebuilt injectors from Precision Auto Injectors... although keep in mind, this was five years ago.
Originally posted by Patrick:
I just ordered a set of these fuel injectors for my Formula - total price (with discount and including shipping to WA)... $77.20 Not too shabby. And no cores are required to be returned.
[This message has been edited by Patrick (edited 04-19-2020).]
So I ended up with a set of the recommended Bosch EV1 injectors. The number on the ones I removed from my motor is 5235210. Just to make 1000% sure, this means I'm going from pintle to pintle and not disk to pintle, correct? I've been reading too many threads again and some people are saying some '88s came with disk style, but I can't imagine that would be the case.
There have been some reports of disc injectors in the 88's but there was some speculation that they were only in the last of the production run. What you have are pintle. You can verify it by looking into the business end. Should be only 1 hole. The EV1's you purchased are a 4 pintle injector so you will see 4 tiny holes in the spray nozzle.
5325210 was used in Pontiac Firebird 2.8L V6 1985-1986-1987-1988-1989 . They would probably be 15# injectors unless the Firebird ran a fuel pressure higher than 43.5 psi. It was also listed for the 85-88 2.8 Fiero and at 43.5 psi, should provide 15#/hr. In actuality, it's 14.65#/hr.
When you push the HP up from 140 in the 2.8 to 160 in the 3.4, the required flow is 17# which is actually 16.66#/hr so you see you need an extra 2 #/hr for the bigger engine. The EV1 you purchased flow 16.7#hr at an 80% duty cycle. Resistance is the same as the 5325210 injectors at 5.90 Ohm.
. There are three kinds of men:
1. The ones that learn by reading. 2. The few who learn by observation. 3. The rest of them have to pee on the electric fence and find out for themselves. Will Rogers
[This message has been edited by fierofool (edited 05-11-2020).]
