  Isolation relay bypass
Isolation relay bypass by pontiacfierokid1985
Started on: 03-02-2020 07:45 PM
Replies: 4 (719 views)
Last post by: pontiacfierokid1985 on 03-05-2020 11:46 PM
pontiacfierokid1985
Report this Post03-02-2020 07:45 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there anyway to by pass the stupid isolation relay on the gen 1 84-86 harness. I know you guys are going to say do the gen 2 harness but no not happening I just rebuilt the gen 1’s lol I have no problem by passing the relay just need a wiring diagram of someone that has done it
Total ratings: 328
Report this Post03-04-2020 04:27 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can make you own Isolation relay from two DPDT relays in a simple circuit. The schematic diagram is somewhere here in the archives (and in my files) but I would refer to the OP to post it again. If you check Rodney Dickman's web site he may be offering a replacement.
[This message has been edited by Dennis LaGrua (edited 03-04-2020).]
FX
Report this Post03-05-2020 10:45 AM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney does make his own replacement isolation relay. I bought one for my 86 GT, works great. I think it was about 40 bucks...Color coded, easy to install...
Report this Post03-05-2020 11:28 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relays and blocking Diodes they often have block amp loads and EMF and power surges from the rest of car.
Relays can wear out but often isn't them that's the problem.
Motors and rest of HL lift can have problems plus often have bad wiring causing low volts causing high amp draw and fry the relays.
See my Cave, Electric Motors
If you bypass or replace any relays and other things are Root Cause then can and likely will have more problems in very near future.
pontiacfierokid1985
Report this Post03-05-2020 11:46 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ended up getting one from rodney should be here Monday hopefully or possibly Saturday. I’ll be installing it ASAP. I hate driving around during the day with my headlights up biggest pet peeve of mine with fieros and 82-02 f bodies lmao
