  Advice removing valve springs
Advice removing valve springs by Zentaury
Started on: 02-23-2020 11:54 AM
Replies: 3 (394 views)
Last post by: Spoon on 02-23-2020 09:57 PM
Zentaury
Report this Post02-23-2020 11:54 AM Click Here to See the Profile for ZentaurySend a Private Message to ZentauryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am replacing the heads of my 1985 GT with a pair of 1987.
I am going to replace the valve stem seals in the “new” heads, I removed 4 of the springs with a lot of trouble and the overhead valve spring compressor broke. I got a Lisle 16750 valve spring compressor, but the springs feel like hard and that they won’t compress at all...
Any advice? Change the tool?
Spadesluck
Report this Post02-23-2020 01:05 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used whatever tool advance auto gave me. It clamps onto the valve on the bottom and reached over to the top of the valve to compress the spring. Work for me.
cmechmann
Report this Post02-23-2020 06:32 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with the last post. The large c clamp type compressor works the best with the heads off. However most will work.
make sure you have something under the head on the valve to keep it from "falling down" while trying to compress the spring.
Also grime, varnish, dried out oil tends to make the retainers stick to the valve. When first starting to compress the spring, take a small hammer and lightly tap the cap. This will help loosen the "keepers"retainers. A pocket screwdriver with a magnet, works great for removing the keepers.
For those who do this in car. Use the "chevy" type handle compressor that uses the rocker bolt. Remove all the spark plugs. Remove all of the rockers. Then move the cylinder down on the cylinder you are working on. Through the spark plug hole, fill the cylinder with soft cloth line. Then bring the cylinder back up. The cloths line will help keep the valves up when compressing the spring.
Spoon
Total ratings: 61
Report this Post02-23-2020 09:57 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've used one of these to compress the valve springs. Easier to crank than to squeeze.
https://www.amazon.com/OTC-...s=automotive&sr=1-10
Spoon
