  87gt cranking not turning over? (Page 1)
87gt cranking not turning over? by Dwayne
Started on: 12-30-2019 04:46 PM
Replies: 52 (1017 views)
Last post by: Gall757 on 01-20-2020 06:09 PM
Dwayne
Report this Post12-30-2019 04:46 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
my son's 87gt won't start so he called me. it cranks fine just doesn't even try to turn over. ran great till then. I started looking into it and so far I got about 45psi at fuel rail. and pulled a plug laid it on intake and got spark. next I placed cyl #1 at tdc and checked for roter at plug wire 1 position. any Ideas on where to go from here.
thanks, Dwayne
Mike in Sydney
Report this Post12-30-2019 05:07 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably the ignition module. Kinda a common fault with age. Try this to confirm. http://easyautodiagnostics....tor_ign_module_1.php
Mike in Sydney
Spadesluck
Report this Post12-30-2019 06:51 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start simple. Ignition module is the simple fix for sure.You checked fuel. Try checking if you got spark as well.
Report this Post12-30-2019 08:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The extra easy test is to crank the starter and look at the tachometer. IF the needle moves, the ICM is working. If it does not....replace the ICM.
[This message has been edited by Gall757 (edited 12-30-2019).]
Report this Post12-30-2019 08:44 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks, Dwayne
He has spark.
Report this Post12-30-2019 08:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...pulled a plug laid it on intake and got spark.
Jumping a few thousands of an inch at atmospheric pressure means next to nothing. A healthy spark will easily jump a quarter inch gap outside of the combustion chamber.
Dwayne
Report this Post12-30-2019 11:32 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
will try to check the icm and place a spark tester on plug wire to check strength of spark. the tachometer is moving as well when cranking. thanks
creaky78
Report this Post12-31-2019 11:42 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick is correct. A weak ignition system can produce spark when plug is inserted into the wire and grounded. When the plug is in the engine compression will not allow the weak system to produce a spark due to the high pressure between the plug electrodes. Also check the coil https://www.youtube.com/watch?v=xmdS4vGB-m8
ltlfrari
Total ratings: 127
Report this Post12-31-2019 03:49 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need spark (in the cylinder) and fuel to run.
Use one of those transparent inline spark testers to see if you have spark. Put between coil and dist center.
Throw some starting fluid down it's throat.
If it at least fires and you've got spark then it's fuel, no spark can be ignition module or coil. ICM is most likely. I've them just 'go' twice so far. Always carry a spare (and tools to swap it out) now.
However if it's electrical, it could be a bad wire or connection somewhere that's just given up the ghost!
Dave
www.ltlfrari.com
David Hambleton
Report this Post12-31-2019 09:29 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
On two occasions separated by a few years, my '84 SE quit while driving and wouldn't restart.
Both times showed strong spark with an inline tester. Both times displayed plenty of fuel in the TBI throat.
Both times I replaced the ECM and it started immediately. Your results may vary...
[This message has been edited by David Hambleton (edited 01-01-2020).]
Dwayne
Report this Post01-01-2020 03:00 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
well I hooked up my spark tester to see how strong of a spark I really had and wasn't good...quarter inch if lucky. changed out the ignition module with a used one that I had laying around. tested it with ohm meter prior to install and same result. weak if any spark. decided to change icm with new and same result. ohmed out wiring from icm to ignition coil while bending it up and no breaks in it. pic up coil at 750 ohms. probably going to change out ignition coil with new for sanity sake. don't like to throw parts at it but gettin to that point.
Report this Post01-01-2020 03:08 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will it fire with starting fluid?
Dwayne
Report this Post01-01-2020 03:11 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
good dose of starting fluid and still not turning over
ltlfrari
Total ratings: 127
Report this Post01-01-2020 05:11 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starter fluid and no bang indicates no spark in the cylinder.
Apart from the coil, check the lead from the coil to the dist cap. It's unlikely all 6 of the ones from the dist to plugs all went bad at the same time
Also check dist cap and the rotor.
Dave
www.ltlfrari.com
Report this Post01-01-2020 05:52 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked to see if it has jumped time?
Timing mark up and rotor at #1?
Dwayne
Report this Post01-01-2020 06:05 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea, checked for continuity of coil plug wire but didn't ohm out. gonna do the cap and rotor as well. just odd ran fine then sat for couple days and now won't turn over. I did see the rotor lined up with #1plug wire at full compresson and at about 0-10deg. same with timing light while cranking. confused...
thanks
Dwayne
Report this Post01-03-2020 12:16 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
just changed the ignitiin coil, cap and rotor and I got it the fire up. Now for some reason that only has a miss. timing reading about 10deg. hooked up to my spark tester an all 6 fired good and strong. as I was testing wires 3,5 and 6 it ran really bad couldn't keep it running. One other part that I haven't changed was the pickup coil but it was reading about 750-800 ohms.
thanks
Report this Post01-03-2020 12:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car will not run with a bad pickup coil.
Dwayne
Report this Post01-03-2020 12:38 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
the pick up coil plug didnt look to good when i tested it. it was somewhat brittle. didn't know what kind of voltage goes through it or if it could be shorting out. although if so I would think it would be on random cylinders. odd parked it running fine then sat 3 days then wouldn't start.
Dwayne
Report this Post01-04-2020 01:41 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
thinking... do injectors 1,2 & 4 use the same wiring? when I test them for spark there is really no difference in the idle. when I test 3,5 & 6 it runs really bad
thanks
Report this Post01-04-2020 01:53 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The injectors are on 2 fuses. 1-3-5 and 2-4-6. What do you mean by 'test'?
[This message has been edited by Gall757 (edited 01-04-2020).]
Dwayne
Report this Post01-04-2020 02:09 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry meaning spark test hooked up to end of each plug wire. figured injector wiring would split the way you stated.
Report this Post01-04-2020 04:10 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
So it looks like you have a gummed up injector or 2.
Dwayne
Report this Post01-04-2020 10:16 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
what's the logic...willing to learn
thanks
Report this Post01-05-2020 10:34 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I could be jumping to a conclusion. If you are confident in the condition of the plugs and wires, the next thing to look at is the injectors. If you disconnect one cylinder and the car runs worse, that cylinder is working properly. If you add starting fluid while the engine is running rough and it smooths out briefly, some injectors are not working.
coltabsh
Report this Post01-05-2020 11:18 AM Click Here to See the Profile for coltabshSend a Private Message to coltabshEdit/Delete MessageReply w/QuoteDirect Link to This Post
had somewhat the same issue and found the fuel regulator was dumping fuel in the vacuum line. pull the vacuum line and try to crank the engine and see if you see fuel
Dwayne
Report this Post01-05-2020 12:24 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
no matter what plugs or wires I use it's always the same 3 cylinders that are misfiring. I have had a regulator go before and it was a random misfire and ran very rich. guess going to take the intake off today and look at the injectors and wirimg see what I can find.
thanks
Dwayne
Report this Post01-05-2020 04:03 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dwayne
Member since Sep 2010
just got the intake off and the 3 cylinders that I'm having problems with has a wet look to the carbon build up inside intake and the 3 others have are dry carbon. any ideas. they must be gettin fuel to be wet?
thanks
Report this Post01-05-2020 04:07 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you verified that both fuses are good for the fuel injection?
Report this Post01-05-2020 04:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
How quickly does the fuel pressure drop when power to the fuel pump is cut?
Dwayne
Report this Post01-05-2020 05:08 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea both 5amp injector fuses look good. cyl 1,2&4. have the issue. from what I remember pressure held above 40psi for about 5 min and slowly dropped for next 10 min.
Report this Post01-05-2020 05:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are all your fuel injectors identical? Silly question, but the symptoms are odd.
Dwayne
Report this Post01-05-2020 05:28 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was wrong. just tested fuel pressure and my pressure went from 45 to 25 within couple minutes.
Report this Post01-05-2020 05:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A... ha! 3 injectors are stuck open or not closing completely.
[This message has been edited by Gall757 (edited 01-05-2020).]
Dwayne
Report this Post01-05-2020 05:49 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
that's crazy. parked car at night running fine. first thing in morning...rotor and injectors? gonna try to clean them up while I order new from rockauto.
thanks
Report this Post01-05-2020 05:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That all makes perfect sense... whereas the following statement doesn't.
I suspect what you meant is that the engine turns over, but it doesn't start.
[This message has been edited by Patrick (edited 01-05-2020).]
Dwayne
Report this Post01-08-2020 08:45 AM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes it was turning over but not starting. finally.
got a chance to get back to working on it last night. I got the injectors out cleaned and tested them best I could. pressurized with carb cleaner, observed spray pattern and all ohmed out at 16.1. put everything back together with the injectors placed in opposite cylinders (good in the bad and bad in the good) to see if the problem moves to new cyl.
well the same cylinders are running bad. I checked the pressure at the rail with the return line pinched and it it is holding solid 65lbs. took 20 min to get down to 45 and stayed there. seems like the leaking injector thing was fixed. after removing clamp off the line the pressure dropped to 20 within couple min. now it seems like another problem in the tank.
it still runs like crap and the same 3 cyl are acting up even after swapping injectors. pressure on start up and idling is 40psi. shouldn't that be enough to feed injectors? did notice the 3 cyl that run bad are at the far side of the rail if that means anything.
i know I have to move to the tank next. shouldn't the 40psi hold an idle? how do you go about problem in the tank?
thanks a bunch.
Report this Post01-08-2020 09:56 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, 40 lbs. should be enough. Have you done a compression test?
Dwayne
Report this Post01-08-2020 11:52 AM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't done a compression test. I should. I am.
that means 2 cylinders on one side of engine and 1 on the other ...sounds odd.
Dwayne
Report this Post01-09-2020 04:57 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
compression checked out all cylinders about 130-140 psi.
upon doing test I decided to put screwdriver from injector to my ear and the cylinders that I'm having a problem with aren't ticking thru the screwdriver. think I found my problem. any idea how to attack that problem?
thanks
