  Round belt moulding / rear bumper cover
Round belt moulding / rear bumper cover by TXGOOD
Started on: 12-16-2019 01:15 PM
Replies: 7 (263 views)
Last post by: TXGOOD on 12-16-2019 08:45 PM
TXGOOD
Total ratings: 87
Report this Post12-16-2019 01:15 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a couple of questions regarding the rear bumper cover.
Will a rear bumper cover from an 88 GT fit on an 88 coupe?
Also, has anyone had any luck with any certain repair / fillers for the plastic belt moulding that is made onto the rear bumper cover ?
I have a cover but the belt moulding is really damaged as in pitting etc, from sun exposure.
I will more than likely have to paint it but I figure there must be some sort of epoxy, etc filler that can
smooth out the damage in it.
Thanks
Report this Post12-16-2019 02:41 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The bumper covers are made of an epoxy material called RIM, sometimes called RRIM. (re-enforced reaction injection molding). There are body fillers made for RIM, available at your local auto paint store.
As for the fit question...you can physically attach the bumper cover, but sometimes it looks stupid because it does not match the lines on the rest of the car.
[This message has been edited by Gall757 (edited 12-16-2019).]
Total ratings: 465
Report this Post12-16-2019 03:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, the wheel well liners won't even be close to matching up to the different body lines at the sides of the rear bumper cover.
Total ratings: 154
Report this Post12-16-2019 05:03 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you get the bumper cover, grab the wheel well liners, too. There's a small filler tab stapled to the liner that covers the wider area of the aero trim at the bottom. Aero trim on on the rear of a base coupe does make it look a little Butt Heavy to me. Envisioning what Patrick said, the fastback has a little wider hips, so the fender well liners may still leave a gap around the edges.
[This message has been edited by fierofool (edited 12-16-2019).]
Total ratings: 465
Report this Post12-16-2019 05:12 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...although the liners that match the rear bumper cover will then not match the body lines to the front of the wheel wells.
Total ratings: 207
Report this Post12-16-2019 07:21 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uh, yes they will...the lower panels by the door are the same (except for the mounting holes for the cladding on the GT.
Total ratings: 465
Report this Post12-16-2019 07:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uh, yes they will...the lower panels by the door are the same (except for the mounting holes for the cladding on the GT).
I don't quite follow what you're stating. The issue isn't the "lower panels".
Without having to go out in the dark and rain to look , if I recall correctly... The wheel well liners on aero-trimmed Fieros fit into the backs of the aero (GT) rocker panels. On non-aero Fieros, the wheel well liner design is a little different as the rockers are different/smaller.
It is possible I'm thinking of the way the front wheel well liners fit.
[This message has been edited by Patrick (edited 12-16-2019).]
TXGOOD
Total ratings: 87
Report this Post12-16-2019 08:45 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will be using Aero ground effects that I`m gping to customize.
In the front I`m going to use one of the Munson bumper covers that Jimmy used to sell.
