Stick cars can suck oil thru valves and/or rings when you "engine brake" the car.
Auto cars can do this too but not obvious until is a really bad problem in most cases.
Can be oil drains block w/ crap keeping oil in the head. Look thru oil fill hole etc to see if the head is very wet to puddling oil there. Most engines should be wet but flooded w/ oil on the head.
Can be iffy valve seals.
Can be iffy valve guides too.
"Cheap fix" is replace the seals but know that may not help much if the guides or pistons rings are worn.
Check PCV system and make sure drains holes in the head to bottom end isn't blocked. If needed to clean drains try small bore gun cleaning kit w/ brush tips only.
Fix it ASAP.
Burning oil can wreck O2 sensor and Cat very easy.
