  Wilwood D154
Wilwood D154 by jjd2296
Started on: 08-21-2019 04:28 PM
Replies: 8 (1127 views)
Last post by: wftb on 08-23-2019 08:18 PM
jjd2296
Report this Post08-21-2019 04:28 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone ever use these wilwood D154 calipers on the front with the zettner brake upgrade? On the 11.25 rotors. They are a direct replacement for the GM calipers used in this swap (same as Archie base swap) but come in dual piston. Reason why I’m thinking of these is because the design of the GM front calipers for this swap result in a subtle clank from the brake pads as the inner pad has a retainer clip that fits inside the caliper piston which never sits tight enough. The wilwoods are a different design and nicer shape than the GM. Ones.
Blacktree
Total ratings: 350
Report this Post08-21-2019 11:56 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the Wilwoods are a "bolt in" replacement for the D154 calipers. I installed a set on the front of my Fiero, with the V8 Archie adapters and LeBaron rotors.
However, the hydraulic connections are different. The Wilwood calipers don't use banjo fittings. IIRC, they use pipe thread fittings.
Spadesluck
Report this Post08-22-2019 12:15 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you are telling me these will work with my Archie brakes?
jjd2296
Report this Post08-22-2019 07:15 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
You sure? Maybe you have an old set. Everything I have read says they have banjo fittings? Even summits ad says banjo fitting. And so do you have any brake pad clanking noise with these?
https://www.summitracing.co...wEAQYAiABEgJ2FfD_BwE
jjd2296
Report this Post08-22-2019 07:31 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
I just watched an install video and they use a banjo bolt. You might not have this model?
Johns 4.9
Report this Post08-22-2019 02:15 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I use these Wilwood calipers with the 11.25 rotors instead of the GM Metric caliper. Direct bolt in, uses banjo fittings, and light weight. Wilwood 120-7197 D154 GM Metric Single Piston Floater Caliper. I think you will be very happy with any caliper upgrade from Wilwood regardless of fittings. I like your choice of calipers. Cheers
Blacktree
Total ratings: 350
Report this Post08-22-2019 04:27 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I must've gotten an older model.
Johns 4.9
Report this Post08-22-2019 04:39 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree,
I've seen them with both fittings. To be honest with you, I'm not a big fan of banjo fittings. I prefer the 1/8 NPT fittings and braided steel hoses. Less areas to leak.
Cheers,
John
wftb
Report this Post08-23-2019 08:18 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a set of the bare AL Willwoods that I am not using. 2.5
" piston. Cant find them, I have looked everywhere. I use a dual piston Wilwood caliper on the front that has an area of 4.12 sq inches and I like it a lot. I use stock rear brakes and I have a bias adjuster to prevent front lock up. The calipers can be seen in my thread on page 21, they are part #120-11872-RD. There are lots of these calipers available in different piston sizes, black or red powder coated. Super light and much nicer than any of the other calipers that fit the Zettner brackets. They use banjo fittings and have top and bottom bleed screws. My thread:
https://www.fiero.nl/forum/F.../HTML/000029-21.html
Page 21
[This message has been edited by wftb (edited 08-24-2019).]
