  intercooler fluid for the 3.8sc whats everyone use?
intercooler fluid for the 3.8sc whats everyone use? by ttt123
Started on: 08-13-2019 01:24 PM
Replies: 13 (351 views)
Last post by: Blacktree on 08-16-2019 08:03 PM
ttt123
Report this Post08-13-2019 01:24 PM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious what people are you using .. and liking for intercooler fluid for there 3.8sc swaps. Anyone have any special blends, brands, tricks that have used and suggest.
Any input?
vette7584
Report this Post08-13-2019 09:59 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
i am using 50/50 green coolant and distilled water. i think it works good. i plan on adding a temp gauge to the system this winter, i want to monitor the temp. was also thinking about adding fans to heat exchanger.
ttt123
Report this Post08-14-2019 07:09 AM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
The temp gauge is a great idea, I didn't think of that so think you! would be interesting to try different things and track the effects. Fans would be nice for city driving for me.
Total ratings: 328
Report this Post08-14-2019 09:28 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
x2 on the 50/50 Green Antifreeze and distilled water mix. I did not add a temperature gauge to the system but I do often monitor fluid temps with a digital infrared laser thermometer.
ttt123
Report this Post08-14-2019 09:45 AM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for chiming in. I was expecting to see some wild concoctions and ideas from people but just plain ole coolant huh lol
anyone ever here of some validity to misting the cooler?
I've never ran a water to air cooler so I'm kind of just thinking out loud and seeing what others who have say about them
Thanks guys
Total ratings: 328
Report this Post08-15-2019 11:51 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys
Not sure how much gain you would see by misting the heat exchanger.
ttt123
Report this Post08-15-2019 07:11 PM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok. Ill stick to the basic triedand tested methods
Blacktree
Total ratings: 350
Report this Post08-15-2019 10:34 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 50/50 water/antifreeze mix will work, but is not optimal. The coolant for the heat exchanger should never reach the boiling point of water. So antifreeze is overkill. Plus, antifreeze reduces the heat capacity of the water. So you could use 75% water / 25% antifreeze, for better heat transfer.
That said, my preferred mixture is 1 teaspoon of powdered dishwasher detergent (for dishwasher machines) for each gallon of water... NOT dish soap that comes in a squeeze bottle. That stuff will foam up and make a huge mess. The dishwasher detergent reduces the surface tension of the water, which improves heat transfer. Also, the detergent keeps bacteria away.
[This message has been edited by Blacktree (edited 08-16-2019).]
pmbrunelle
Total ratings: 63
Report this Post08-15-2019 11:01 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Antifreeze is a necessary evil to prevent the water from freezing, and thus expanding and rupturing the pipes in the winter. You don't use antifreeze because it makes for a better coolant.
Note that OP is in Michigan, not Florida.
I once put hand dishwashing soap in a dishwashing machine. Bubbles poured out onto the floor, and there were so many bubbles that the pump lost its prime; the pump inlet could only suck bubbles. Somehow my dad was able to bring home some magic chemical home from work that made the bubbles go away.
I think that spraying water on a heat exchanger's fins is a rather indirect way of cooling the air; on my Fiero I'm going to spray the water into the engine's intake ports.
[This message has been edited by pmbrunelle (edited 08-15-2019).]
Blacktree
Total ratings: 350
Report this Post08-16-2019 12:28 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by pmbrunelle: Note that OP is in Michigan, not Florida.
Good point. In that case, the 50/50 water antifreeze mix would be the more prudent choice.
ttt123
Report this Post08-16-2019 06:45 AM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
interesting guys. so what about the dishwashing detergent along with the 50/50 coolant? I think the fans as well would be a good idea for slower speeds or city driving. My wife and I cruise woodward a lot on Saturdays so speeds wouldn't be that fast for air flow.
Blacktree
Total ratings: 350
Report this Post08-16-2019 11:39 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never tried mixing chemicals like that, not sure if they're compatible.
An intercooler fan would be a good idea. It would also be a good idea to put a temperature switch on the intercooler, so the fan only runs when needed.
ttt123
Report this Post08-16-2019 06:17 PM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good stuff guys. Push or pull for fans? What about oil cooler? Anyone feel its a worth the work benefit? On my porsche the gas also goes through the a/c system. Someone on the porrsche forum explained why but i don’t remember.
Reason im asking this stuff is im just thinking of all the small stuff that can be done for a horse here and a horse there i want to do. i e used to have a friend with a Dino shop when I was building Camaros and he went through his engine before he did all of the small stuff like underdrive pulley‘s coolers etc. etc. and he picked up like an extra 20 horse when it was all said and done and thats always stuck with me about freed up hp.
Sorry for the grammar I’m typing this one on my phone Lol
Blacktree
Total ratings: 350
Report this Post08-16-2019 08:03 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a general rule, puller fans are more efficient than pushers. That said, if a puller fan won't fit, then a pusher is better than nothing.
