  1984 Fiero Base: Stop Lights stay on, hazard lights don't blink, clicking noise?
1984 Fiero Base: Stop Lights stay on, hazard lights don't blink, clicking noise? by HomelandSecurity
Started on: 08-07-2019 05:55 PM
Replies: 15 (222 views)
Last post by: HomelandSecurity on 08-09-2019 12:27 PM
HomelandSecurity
Report this Post08-07-2019 05:55 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
1984 Fiero Base SE, the rear lights stay on, the hazard lights come on but don't blink, I replaced the fuse but nothing changed. When I detach or attach the battery cable I hear a clicking noise. Any ideas? Please try and be detailed about any solutions you come up with. Thanks.
Total ratings: 207
Report this Post08-07-2019 06:05 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do all of the rear lamps stay on, or only the outside lamps?
HomelandSecurity
Report this Post08-07-2019 07:04 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rear lights stay on, not just the sides.
Total ratings: 207
Report this Post08-07-2019 10:21 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
So ALL of the red rear lamps stay on.
Are the backup lights on as well?
(Not asking about the side marker or license plate lights.)
[This message has been edited by olejoedad (edited 08-07-2019).]
HomelandSecurity
Report this Post08-07-2019 11:00 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the brake lights are working. The rear (white) lights do come on in reverse.
Nickoman
Report this Post08-08-2019 08:41 AM Click Here to See the Profile for NickomanSend a Private Message to NickomanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds to me like you have a Relay that is going bad or stuck. I had the same thing happen in my 84. as well as my s-10.
HomelandSecurity
Report this Post08-08-2019 09:00 AM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the 1984 Fiero, are they the two black boxes on firewall (inside the engine compartment) behind the driver's seat? Can they be cleaned or do they need to be replaced?
Do you think the brake light switch under the brake pedal might be the cause of it, if it is stuck?
Nickoman
Report this Post08-08-2019 09:20 AM Click Here to See the Profile for NickomanSend a Private Message to NickomanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those should be the Fuel pump relay and AC if you got it.
To check the switch, unplug the switch and listen for the clicking noise you hear when disconnecting the battery.
When I get home from work I will check the location of the brake relay for you. I can hear it click behind my head somewhere when the car is off.
HomelandSecurity
Report this Post08-08-2019 09:36 AM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you mean disconnect the brake light switch under the pedal, and then listen for clicking noises?
Thanks.
Nickoman
Report this Post08-08-2019 10:04 AM Click Here to See the Profile for NickomanSend a Private Message to NickomanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah give it a try
Nickoman
Report this Post08-08-2019 10:20 AM Click Here to See the Profile for NickomanSend a Private Message to NickomanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nickoman
Member since May 2017
Thanks.
You can Jump the switch with a paper clip to simulate the switch cycling.
Report this Post08-08-2019 12:18 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 stop/turn have 2 relays controlling 1 bulb each. Relays are Not the problem here.
Hazard Does Not work on purpose when rear stop/turn bulbs are on. Most to All vehicles w/ Red only taillight are make this way from the factory so brakes have priority. So likely Hazard isn't a problem either.
Likely Brake light Switch on pedal or Blinker switch in the column are "bad."
Unplug pedal switch w/ orange and white wires.
If off the switch is bad, switch adjustment moved, or pedal have problems.
Still On then something in blinker switch or wires to it is wrong.
Note: 2 Bulbs controlled by relays get power thru csty fuse. pull that fuse will turn off but relay's will still make noise because coil is on taillight circuit.
HomelandSecurity
Report this Post08-08-2019 02:15 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I tried. I found the brake light switch above the pedal, and I was going to detach the wires to it first, but there was another block above it with two black connectors, I pulled one of those and the rear tail lights (all four bulbs) went out. Turned on and tested everything, everything works . . . rear lights (2 outside bulbs), hazard, backup, stop, turn signals, markers. The rear (red) lights in the middle don't come on now . . . except when I push the brake pedal.
So, what exactly did I pull? And, as important . . do I need it?
HomelandSecurity
Report this Post08-08-2019 04:26 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
HomelandSecurity
Member since Aug 2019
I don't see a way to post a picture of it.
HomelandSecurity
Report this Post08-09-2019 12:25 PM Click Here to See the Profile for HomelandSecuritySend a Private Message to HomelandSecurityEdit/Delete MessageReply w/QuoteDirect Link to This Post
HomelandSecurity
