  Seat stud bolt swivels
Seat stud bolt swivels by Brent7088
Started on: 08-01-2019 11:13 PM
Replies: 7 (339 views)
Last post by: Brent7088 on 08-05-2019 05:14 PM
Brent7088
Report this Post08-01-2019 11:13 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All - I decided to tackle something that's been needed for a long time..
One of the threaded studs/bolts on my PS seat swivels and so the nut won't tighten all the way down. I managed to get the nut off a few years ago but tightening it back down snug is obviously another story.
I understand I would need to remove the seat and peel the carpeting back to access the floor pan to do anything further. Can anyone offer any solutions to replacing the bolt or to get it to tighten back down? I had thought about renting an arc welding machine to spot weld it all around but don't know much about them yet and don't know if that would even be a viable option, due to the type of metal the flooring is made of. I really don't want to cut out any of the surrounding metal if I can help it.
Please let me know if anyone has any ideas - thank you in advance.
[This message has been edited by Brent7088 (edited 08-01-2019).]
Total ratings: 207
Report this Post08-02-2019 12:15 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the threads are good on the stud, and it's just loose, a couple of small welds may solve your problem.
Pull the seat and carpet from the passenger side, grab some movers blankets and drive to a local welding shop.
Brent7088
Report this Post08-02-2019 03:47 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe, thank you for your suggestion. This may be a stretch, but what if I used a handheld butane blow torch and "super alloy 5" rod and flux? Or would I not be able to get it hot enough for the job?
Total ratings: 207
Report this Post08-02-2019 03:55 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uh, good luck with that......
Arc welding the small weld needed puts very little heat into the car compared to a gas setup.
Bzzzztt and it's done.
Shield interior from sparks with the moving blankets.
Darrelk
Report this Post08-02-2019 05:49 PM Click Here to See the Profile for DarrelkClick Here to visit Darrelk's HomePageSend a Private Message to DarrelkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, just bite the bullet and find a good welding shop. Guys with frame shops are quite competent about doing this type of work. As said get as much stuff out of there way as you can and protect everything. Sparks can throw some distance. I've done this many times over the years. Only had one teeny fire......put it out in a few seconds, thankfully.....
Brent7088
Report this Post08-02-2019 09:18 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe and Darrelk, thank you for the advice. I will probably just take the advice of taking the car to a welder and have it done professionally; I just need to work on prepping it with a few of those blankets.
It's hard for me to imagine there aren't many others who have had this same issue. I did find one thread on it, but can't seem to find it at the moment so I'm not sure if theirs was ever fixed.
Total ratings: 328
Report this Post08-04-2019 02:29 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This just happened to me on one of my vehicles. Had to tack weld the stud in place with the mig. This is common as the nut becomes rusted on and when torque is applied they break loose. Got to remove the seats, pull the carpet and weld. Should you not want to pull the carpet, you might get by by placing a sheet of sheet metal round the stud with a 1" hole as a carpet protector.
[This message has been edited by Dennis LaGrua (edited 08-04-2019).]
Brent7088
Report this Post08-05-2019 05:14 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis - thanks for chiming in - good suggestions... I will consider them when it's time to take it to a shop.
