| quote | Originally posted by fieroguru: Check the chassis connector by the brake booster. Maybe one of the terminals isn't properly seated. |
Could be but would be more the 1 w/o a connection.
Only turn/park and marker or HL bulb too? All are normal or LED?
Front bulb is ground for marker. See my Cave,
LED Marker Light first part tells how it works.
Even if bulb is good/new... Front bulb or the socket have no ground or base of bulb getting crap connection then both won't work.
Pull socket and look. wiggle the bulb etc. Most front Socket come out the back but raise HL and disconnect motor trying that.
If metal socket... Try grounding the socket.
Then Try using a pin push into/thru black wire and ground that.
