In short...
Fiero and some other seat belts design to lock in a crash or hard braking by tilt weights sim to most Arcade games for the last 60+ years.
CLICK FOR FULL SIZE |
After they lock will unlock again depending on car position and damage.
They
Do Not Lock by pulling out at any speed when parked on level ground because they are not made to do that.
Parked or drive on a Hill
CAN lock them easily and will not work right until car is on less of a grade to level again.
Fiero Seat belt mech is at shoulder level and doesn't collect trash like others.
But if Seat Belt itself is dirty then can have problem retracting etc because of this.
If dirty, pull belt out and block it out.
Clean with soft brush, mild soap and rinse and allow to dry completely before you allow the mech to retract.
Look for EU equivalent to Dawn dish soap or Simple Green. Both are safer to the belt then most are and if some left in the belt shouldn't bother people skin.
If local water is hard... Final rinse w/ cheap bottled water.
Note Even many new cars have similar locking methods for normal driving But Most have "pretension" seat belt parts control by the "Air bag" module. If you see SRS light then these parts can have problems not just air bag(s) in a car. If the belts fire the pretension or just goes bad for wear or any other reason then you have to replace whatever part. Most have explosive parts that can hurt or kill you if not handled properly.
