  Radiator Fan Dead - Possible 12V Motor Replacements?
Radiator Fan Dead - Possible 12V Motor Replacements? by 2002z28ssconv
Started on: 05-19-2019 11:26 AM
Replies: 9 (371 views)
Last post by: fierofool on 05-24-2019 08:43 AM
2002z28ssconv
Total ratings: 51
Report this Post05-19-2019 11:26 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm running low on spare radiator shroud/fan assemblies. I have a couple with dead motors now. Has anyone ever found a motor that could be swapped into the shroud?
Of so, please share so I don't have to figure it out... and I'll make a tutorial. We gotta save the old parts.
Total ratings: 207
Report this Post05-19-2019 12:06 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a Fiero shroud and install a modern 16" aftermarket fan assembly.
I think Forum member fierosound came up with this upgrade, it works great and looks good too!
Blacktree
Total ratings: 350
Report this Post05-19-2019 02:29 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt you'll be able to adapt a different motor cheaper than buying a stock replacement, unless you get used parts. Even the cheapest 16" aftermarket fans cost more than $50.
Edit to add:
Advance Auto has the fan motor for about $25 (part #35656) [ LINK ]
Also, the Fiero Store has it for about $50 (part #55106). [ LINK ]
[This message has been edited by Blacktree (edited 05-19-2019).]
Report this Post05-20-2019 01:12 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dead Motors Relay and Switches can be a symptom, not the root cause.
See my Cave, Electric Motors and Wire Service
Often the Rad Fan have crap ground and crap power because red wire have to go thru several connections before get to the relay and relay may be dying too.
And I mean Ground. Fan Ground uses same screw but is Not shared ground w/ HL etc and only connects to frame near left HL assembly. Is a bigger wire then other too.
Add most GM FWD and Fiero Rad Fans was never made to run all the time. Adding switches or shorting out the green control wire can shorten the motor(s) life a lot.
Yes, Fiero AC control head does same but GM didn't care if fan dies after Warranty ran out.
Heater Blower Motor can have a short life when run a max speed too. Both are nearly identical design and made cheap as possible.
If you think aftermarket fan/blower motors are much better... Most of them are same thing hating to be on all the time.
2002z28ssconv
Total ratings: 51
Report this Post05-20-2019 07:33 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit to add:
Well there ya go.... Thanks BT (and others). I never even thought that those were on the shelf, store bought items.
FX
Report this Post05-20-2019 10:09 AM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney has different temp rated fan switches for the engine, and thermostats. I have a combo from him the allows for minimal fan operation. Check RD's site out for different combinations, and his recommendations. The stock 235 temp sender in these Fiero's is too high.
Bobby
[This message has been edited by FX (edited 05-21-2019).]
darbysan
Report this Post05-21-2019 10:34 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a little more expensive, but you can graft a new Volvo fan onto the Fiero shroud, and have a 2 speed fan if you choose. New, less than $100 on Amazon. Used much cheaper, but you run the risk of a bad motor or cracked fan blade ( I got the cracked fan blade!). This fan really cools, too, if you live in a warm climate.
https://www.fiero.nl/forum/Forum2/HTML/121712.html
'87 GT , '00 3800 Series II SC, 4t65e, Vue Power Steering. (SOLD)
Total ratings: 207
Report this Post05-21-2019 12:39 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit to add:
Amazon has aftermarket fans for as little as $39.99. Free shipping with Prime membership.
The modern fans draw lower amps and move more air than the OEM Fiero fan.
George P Wood
Report this Post05-24-2019 12:13 AM Click Here to See the Profile for George P WoodSend a Private Message to George P WoodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 154
Report this Post05-24-2019 08:43 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got notice yesterday that Rock Auto is having a Wholesale Closeout Sale on Fiero parts, including radiator cooling fans. $9.47 for cars with AC and $17.48 for cars without AC. These are both VDO motors.
