  LFX 3.6 V6 questions
LFX 3.6 V6 questions by RussellCupples
Started on: 04-27-2019 04:32 AM
Replies: 6 (387 views)
Last post by: Daryl M on 04-27-2019 08:25 PM
RussellCupples
Report this Post04-27-2019 04:32 AM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a stroke and luckily all it messed up was my memory and some of my mechanical abilities . With that being said what straight shift trans should I use in a 1988 Fiero and where can I get a flywheel also is there a video showing a detailed LFX installation?? I hope you great folks can help . Thank you so much in advance .
Total ratings: 237
Report this Post04-27-2019 09:19 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Saab 9-3 with turbo 2.8 V6 was available with the F40 six speed trans from '09ish until they stopped building them. That transmission bolts directly to the LLT, LFX, LGX and other high feature V6's (like the LP9 2.8 turbo).
All the stock Saab flywheel/clutch parts should work fine.
RussellCupples
Report this Post04-27-2019 05:55 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
So unless someone else knows something then we are stuck with a 4 speed auto, right .?I looked the prices up and can't afford the f40 trans
Daryl M
Report this Post04-27-2019 07:55 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check carparts.com for a 2006-2012 manual transaxle for the Saab 9-3 with the 2.8l v6. There is one in Las Vegas and one in Albuquerque, each is $375.
[This message has been edited by Daryl M (edited 04-27-2019).]
Daryl M
Report this Post04-27-2019 08:06 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Member since Aug 2016
By the way, the 4 speed auto does not come with the LFX engine. The LFX was coupled to the 6t70 transmission.
Daryl M
Report this Post04-27-2019 08:15 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
This flywheel will work for the LFX/F-40 6 speed.
https://www.specclutches.com/741094/
Daryl M
Report this Post04-27-2019 08:25 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
