  Idles perfect, put in gear it dies, tcc is disconnected
Idles perfect, put in gear it dies, tcc is disconnected by thejimbud
Started on: 03-30-2019 03:35 PM
Replies: 14 (579 views)
Last post by: thejimbud on 05-19-2019 10:52 AM
thejimbud
Report this Post03-30-2019 03:35 PM Click Here to See the Profile for thejimbudSend a Private Message to thejimbudEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone,
I have searched this forum inside out........85 SE V6 starts right up, idles perfect at 900, the tcc has been disconnected for 2 years, almost every time I put it in gear my rpms drop to about 400-500, sputters out dead. No vacuum leaks, new IAC, newer TPS, trans fluid is full, new fuel pump last year, great fuel pressure, and no SES light. Happened two days ago and for the life of me I am at a loss of ideas. I tested the MAP with a multimeter and did the hand pump test as well, all numbers came back acceptable. No EGR, it is blocked off. New 02 sensor last year too. Smells like running a little rich but not terrible. I am replacing the MAP Monday just in case. Any ideas where to proceed ?
Thanks in advance your time and knowledge everybody!
thejimbud
Shho13
Report this Post03-30-2019 10:01 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe your brake booster is leaking internally, that would cause a massive vacuum leak only as soon as you press on the brake pedal. You would need to press the brake pedal to put into drive..........
To test, use a pair of needle nosed vice grips, tips wrapped in a few rags to not damage rubber hose. Squeeze and completely block the hose that supplies vacuum to booster. KEEP IN MIND BRAKE PEDAL WILL FEEL "HARD", AND BRAKE FORCE WILL BE REDUCED, PRESS BRAKE PEDAL HARRRRRRD WHEN PUTTING IT IN DRIVE TO PREVENT CAR FROM MOVING.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Easy8
Report this Post03-30-2019 11:49 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does it keep running if you go past drive to neutral? Will it keep running if you give it gas ( point the car in a safe direction.. like not at ANYTHING) Does the car lurch when this happens or does it just bog down and die?
Report this Post03-31-2019 10:03 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, Booster and it's line can cause major vac leak.
May need ECM scanner too. Tran's NS Switch or wires to it may be iffy and ECM is not seeing the trans in gear.
Or Can be iffy engine/trans mounts pulling wires and causing ignition fuel etc problems.
Can't "go past drive to neutral"... Can go pass Reverse not drive.
Yes... TCC locked will try to make car move in reverse or drive. Unplug TCC may not help here depending on exact problem.
IOW Solenoid really stuck open the TCC stays locked or enough to stall engine and try to move the car.
Only helps to unplug when valve is slow to close because dirt etc makes some more resistance for core spring closing the valve.
Even if core returns to close position, valve "Rubber" can be bad and leak and keep TCC locked.
thejimbud
Report this Post04-01-2019 06:43 PM Click Here to See the Profile for thejimbudSend a Private Message to thejimbudEdit/Delete MessageReply w/QuoteDirect Link to This Post
New MAP sensor did not solve this issue. I can shift into drive but it stalls just like when I put it in reverse, if I shift back to neutral sometimes it recovers without touching the gas pedal. Ogre, if you could elaborate a bit more on auto trans sensors I’m all ears sir. I am not familiar with an IOW which you noted on your reply. I’m also replacing cap and rotor cuz they looked a bit corroded and it’s a cheap $20 AC Delco job which I should’ve done already anyways.
Total ratings: 259
Report this Post04-01-2019 07:49 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did this gradually get worse, or start all of the sudden?
If gradually, I would clean the bore around and edges of the throttle body plate as well as the IAC passage. On high mile engines carbon can build up in these areas and start restricting airflow. You start to see if first with transitions from park to drive.
thejimbud
Report this Post04-02-2019 03:47 PM Click Here to See the Profile for thejimbudSend a Private Message to thejimbudEdit/Delete MessageReply w/QuoteDirect Link to This Post
This all of the sudden happened.
Report this Post04-02-2019 05:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
NSS is on the trans @ shifter.
Bad or iffy NSS, Iffy Shifter and/or Cable, and other things can make NSS not "Sending" ECM "signal" car in/out of park/neutral. ECM scan tool quickly tell you this as you shift thru different points.
See my Cave, Neutral Safety Switch for what it look like.
You already Unplug TCC in front of Trans right?
Unplug usually stops TCC problems but not always or a lest right away.
Sometimes have to wait until valve closes after solenoid got hot, binding from dirt or both. That can take minutes to hours or even more.
But you have unplug for years so isn't same problem.
Look at how fluidmaster works for toilets... (quick link @ ~ 2:30 min mark) TCC solenoid valve work similar to it. If "rubber" is torn etc and leaking AT Fluid internally then TCC can stay locked or part locked same a foot on clutch pedal pushing part way down. Most times enough load the car and will try move at idle and stall the engine unlike try to move a little at idle but TC works and won't stall.
Total ratings: 259
Report this Post04-02-2019 07:30 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the range switch on the transmission. There are different idle parameters for Park vs. Drive. It might be loose and not in the right position or one of the connectors could have gone bad.
Phil
Total ratings: 154
Report this Post04-03-2019 02:13 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same sort of thing happened to my son's car once. Turned out to be a stuck/dirty idle air control valve. To check give it a little gas while shifting into gear.
Report this Post04-04-2019 11:43 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would guess IAC as well. You said its new are the wires fine? Any check engine lights?
armos
Report this Post04-07-2019 02:44 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the first post you said it "sputters" at about 500rpm, so it sounds like it's running for a moment, not just shutting off. If I'm interpreting that correctly then it sounds like a tuning/sensor issue, not a locked TCC issue. If it was the latter the engine would just immediately stall.
Was the car being driven consistently before this happened, or has it been sitting?
Can you keep it running if you give it throttle? Have you driven it at speed since this issue started? Doing so will allow the ECM to recalibrate the IAC position.
Do you have a broken connector at the IAC? If it's broken then it can be plugged incorrectly.
I also agree with cleaning out the IAC passages. If it's not been done then they're probably pretty grimy.
The ECM detects 2 statuses from the Neutral Safety Switch - in gear and out of gear. When you shift the lever into a drive position, the ECM will anticipate by opening the IAC (and maybe make early fuel adjustments, not sure). You can notice how the idle changes in that moment when you move the shift lever but the transmission hasn't actually engaged yet. If you don't notice the ECM reacting during that moment between moving the lever and actual engagement, then I suspect it's not getting the "in gear" signal.
The signals at the NSS must be documented somewhere. If you can find that info, then you could check that with a multimeter and try to determine whether it's reliably signaling the correct status.
The easiest and best way to check this (and many sensor issues) is with a laptop running WinALDL or a "scanner", but if you don't have that, then it should still be possible to look into it with your meter.
thejimbud
Report this Post04-07-2019 01:47 PM Click Here to See the Profile for thejimbudSend a Private Message to thejimbudEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took advice from ogre and let it idle for over 20 minutes, outta nowhere it stalls out but gave code 22, I replaced the tps, issue continues. I tried to drive and it barely got out of the driveway, giving it too much gas stalls it too. Could this be a pick up coil failing?? No codes when I tried to drive it.Gonna test spark plug wires too
armos
Report this Post04-10-2019 10:15 PM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
The signaling from the NSS needs to be checked. Check if it's working with either a scanner, or by probing with your multimeter (exactly how depends on the pinout, I'm assuming that info is out there), or at least observe if the idle changes when you move the shifter to a drive position. If the idle changes then the ECM is apparently getting the signal.
http://www.fieros.de/en/v6help/code22.html
says Code 22 is set when TPS signal voltage is < 0.2V for 2 seconds. It also shows the pinout of the TPS connector.
Check your +5V line at the TPS connector. This also goes to your MAP sensor connector - might as well check it both places. If it's not a consistent 5.0V then it's going to cause problems.
You should also be able to check the signal voltage by backprobing into the connector while it's plugged in.
Try wiggling wires while checking these things. Look for anywhere that either the +5V or signal wire could be shorting to ground. Have there been any previous wiring repairs? Check that the wires aren't touching.
thejimbud
Report this Post05-19-2019 10:52 AM Click Here to See the Profile for thejimbudSend a Private Message to thejimbudEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the delay, but here’s an update. After replacing the NSS switch, issue persisted. Turns out the pick up coil and old gas were the culprits...Running great now. Thanks for your help everybody! The coil wires were exposed and corroded really bad. Glad it wasn’t the trans!!
