  Linear Headlight motor Success! (Page 2)
Linear Headlight motor Success! by JMTUT
Started on: 03-26-2019 01:09 PM
Replies: 47 (1956 views)
Last post by: gregr75 on 07-29-2024 10:59 AM
Report this Post04-12-2020 01:43 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have decided to try this route as there is no other choice for replacing a Gen 1 motor. Replacements are not always available and much of time as in my case, once the motor shorts or the brushes fall off the plate they are not re-buildable.
RCR
Total ratings: 102
Report this Post04-12-2020 05:55 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
That was a cool project and upgrade. Instead of a fuse, try an inline thermal breaker.
Bob
LornesGT
Report this Post04-13-2020 11:25 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much did you limit travel down from the 2”?
Report this Post04-14-2020 10:16 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't answer this question but I can tell you that most of the actuators have adjustable cams and limited switches below the bottom cover that can be set for any activation point. You loosen the screw, rotate the cam to trigger the limit switch at whatever position, and tighten the screw. Still don't know if 2" of travel will do it. For this application you are limited to the overall total size of the actuator. This may not be the optimum solution but what else can you do when Gem1 motors are no longer available and those that remain are not always rebuildable.
donuteater306
Report this Post04-20-2020 02:30 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
And to think that Pontiac could have eliminated all of the headlamp operation drama by simply attaching the headlamp door to the rest of the mechanism...like every other manufacturer. Never hear of headlamp door lift issues with other 80's cars from Honda, Nissan, Toyota, Mazda/Ford, etc., etc.
Blitz54
Report this Post07-29-2024 12:14 AM Click Here to See the Profile for Blitz54Send a Private Message to Blitz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Was looking into doing my own linear actuator setup sometime (but damn the actuators are expensive). And I came across this
https://www.firgelliauto.co...rrent-cut-off-module
The youtube video showing it in action is 4 years old, so I guess it became available around the time this thread was last active. Anyway, it looks like it would solve the problems discussed in the thread, it ignores the initial start up current, which is the main problem brought up earlier. Not crazy expensive, possibly could get away with one box for both motors? Not sure on the current draw OPs actuators have but it would be close I think. Two would be better for the fact of if one jams, the other still goes up.
Dukesterpro
Report this Post07-29-2024 10:31 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
No reason this couldn't get hooked up to my new headlight controller. My setup monitors current across both channels (each headlight) independently. They can disregard inrush current and allow you to pass power through a high amperage line independent of the existing wiring.
gregr75
Report this Post07-29-2024 10:59 AM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
-deleted post- irrelevant
[This message has been edited by gregr75 (edited 07-29-2024).]
