  Stock upper intake manifold mod
Stock upper intake manifold mod by zobari
Started on: 03-01-2019 12:27 PM
Replies: 31 (1891 views)
Last post by: zobari on 07-11-2020 03:21 PM
zobari
Report this Post03-01-2019 12:27 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I have modified my second upper intake v6 manifold
There are the pictures :
(Thanks Patrick for the picture resizing advice)
I hope to get better upper rpm and get extra some hp
I have made some other mod and maintenance like exhaust manifold porting, removing cat, sport round muffler and stainless Steel full custom exhaust. Accel Ignition coil performance, performance SPARk câble, ngk new iridium SPARk plug, kn air filter and others oil and gas kn filter, no egr.m, New oil castrol titanium 5w30 with a9 motoreco vl oil additive, All sensors are New, New clutch and oil pan, Idecarbonized the engine with liqui moly intake 5111 and then with a tunap 133 intake bottle.. .
I let you know when I Will install This intake but at the same time I Will change the injectors
[This message has been edited by zobari (edited 03-02-2019).]
pmbrunelle
Total ratings: 63
Report this Post03-01-2019 12:47 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
For sure it will make a difference.
With a stock 2.8 (except for ported exhaust manifolds), I have observed an absolute pressure of 85 kPa in the plenum at WOT.
Therefore, I take the hypothesis that there is a 15 kPa pressure drop across the throttle body and neck.
Hence, I would suppose that if you succeed in maintaining atmospheric pressure in the plenum at WOT, you could increase top-end torque by 18%.
zobari
Report this Post03-01-2019 01:22 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks for your response and that's very interesting. For me.
I Will proceed to the installation This month with the 6 accel 15 lb injectors replacement.
I Will maybe get my 88 gt dynoed next month after the modification.
Total ratings: 466
Report this Post03-01-2019 11:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by zobari:
There are the pictures...
I'm amazed that individuals who are wizards in the shop often have no clue how to properly resize and post images.
I felt this custom intake was rather special... so here's Zobari's images re-posted so that we can all see them.
[EDIT] Zobari has now copied and pasted the six images I re-sized into his opening post (which is what I was hoping he'd do), so I've deleted them from here.)
[This message has been edited by Patrick (edited 03-02-2019).]
Spadesluck
Report this Post03-01-2019 11:30 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will the non aerodynamic square hurt air flow, thoughts? Or will it allow more air to be in the manifold for the motor to take in?
tshark
Total ratings: 68
Report this Post03-02-2019 12:12 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will the top clear the deck lid?
pmbrunelle
Total ratings: 63
Report this Post03-02-2019 12:17 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The concept of a large plenum full of relatively "still air", ready for consumption by each cylinder, is a common concept...
See Ferrari:
Honda:
Previous incarnation of La Fiera's car (which produced good power):
Toyota went against the grain here. I haven't seen other cars like it!
[This message has been edited by pmbrunelle (edited 03-02-2019).]
zobari
Report this Post03-02-2019 02:38 AM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have take the wcf intake manifold as example with my custom touch for the back side and also for the upper side.
I have paied 180 dollar for the weld working.
I think that the wcf intake is too expensive.
I Will clean and repaint it in red as oem color
Blacktree
Total ratings: 350
Report this Post03-02-2019 10:23 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to compliment your welding skills, but I see you hired a welder.
Like mentioned above, the purpose of an intake plenum is to be an air reservoir for the cylinders. The stock plenum has very little volume, so there isn't much air for the cylinders to draw from. The larger volume will allow each cylinder to take in more air during the intake stroke. And that will improve torque.
zobari
Report this Post03-02-2019 10:36 AM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes exactly the first restriction is the neck and then the volume is very thin and insufficient for a v6 engine i think
The trueleo intake will be maybe a bit better in performance but it's very expensive.
That's my last mod on my 2.8 v6 engine
zobari
Report this Post03-03-2019 01:23 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have measured with a 8cm bottle height and I can close the deck lid.
I have demanded to the welder 6 cm for the height on the top.
1,5cm for the bottom.
[This message has been edited by zobari (edited 03-03-2019).]
lou_dias
Total ratings: 67
Report this Post03-05-2019 10:40 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC - I believe it was the PGP V6 intakes that widened the neck and added more dept (and volume) to the plenum and got 20 more hp.
zobari
Report this Post12-09-2019 04:50 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
After 11 months
[This message has been edited by zobari (edited 12-09-2019).]
Total ratings: 466
Report this Post12-09-2019 06:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh heh... that looks massive! I'm quite surprised that the decklid is still able to close.
So, how's it run? Notice a difference?
zobari
Report this Post12-09-2019 07:00 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I can close the deck lid without any problem.
I just start and let running the engine and let warmed the engine in closed loop for 20 minutes in idle.
I Will test the modification This week or next week when the weather Will be better.
I have changed the 6 injectors wiith new accel 15 lb performance disc style and New fuel pressure regulator at the same time.
The Last mod is changing the y pipe by a less restrictive y pipe from fiero store that I've buy.
Notorio
Report this Post12-11-2019 04:05 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't wait to hear about your test drive . Seems like you got a great deal on the welding. So you did the cuts on the intake and also the new pieces yourself? How did you do that and was it difficult?
zobari
Report this Post12-11-2019 04:29 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I have hired a welder (tig aluminium weld)
I have drawed lines where exactly he must cut and I told what I want like measure and shape...
Pay attention for the pcv vaccum hose under the neck you must weld it 2cm to the left (to the trhottle body) because the fuel rail is just under I have rewelded this area..
Before weld working :
Here I have told him to rework also the upper neck :
The vacuum hose for the brake booster line is different between 1988 and 86-87 the hole is bigger for the 88 and I must cut my old 1988 intake and weld this piece of alu on this moded 86 upper intake manifold.
Next week I Will test and let you know.
Next Last mod, remove air filter box restriction and I Will change the y pipe with a performance part and after these Last mod I stop the mods on my engine.
[This message has been edited by zobari (edited 12-11-2019).]
lou_dias
Total ratings: 67
Report this Post12-11-2019 04:42 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
With a 3.4, the middle intake is a big restriction. I used a ported F-body 2.8 intake for my application. The gains start at exactly 4500 rpm where my much older 3.4 dynos would peak.
[This message has been edited by lou_dias (edited 12-11-2019).]
lordfiero
Report this Post12-12-2019 09:56 AM Click Here to See the Profile for lordfieroSend a Private Message to lordfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work but there is more that has to be done if you want max gain..
Ive done maybe a hundred of flow measurement on this intake system. The flow limitation is in the shape of the middle intake manifold. The air path has to be redirected.
zobari
Report this Post12-12-2019 04:09 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information.
I hope to get some torque and hp in low and middle rpm a bit better breathe et hp rpm to 5500rpm if possible, a > 5500-6000rpm intake doesn't interest me that's too high for our old engine i think.
I wil work on the air filter box restriction and i let you know next week with a test drive
[This message has been edited by zobari (edited 12-12-2019).]
jjd2296
Report this Post12-13-2019 06:12 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Why not mod the intake like the PPG cars? That’s what I’m doing as well as Lou’s mod on the middle intake.
[This message has been edited by jjd2296 (edited 12-13-2019).]
Notorio
Report this Post12-14-2019 11:37 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wait, you just gave him the stock manifold with some lines drawn on it and he did the cut-outs on the manifold, cut out all the pieces needed to make the box, etc., and then welded everything and he did all of that for only 180 euros??? Man you got an incredible deal!!
zobari
Report this Post12-15-2019 12:09 AM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes exactly.
And it's a good welder and the price is low.
[This message has been edited by zobari (edited 12-15-2019).]
zobari
Report this Post12-18-2019 12:21 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I've drove the car Today around 30km.
The car runs good.
The low rpm is better (because I've change the injectors maybe)
I've push the engine at 5500rpm for my test and the engine takes easily the rpm I feel a better torque and gain some hp the car is faster than before.
Next Last mod is change the y pipe by a New y pipe performance and put new synchromesh transmission oil.
[This message has been edited by zobari (edited 12-18-2019).]
tmadia
Report this Post12-18-2019 05:04 PM Click Here to See the Profile for tmadiaSend a Private Message to tmadiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool mod! Would love to see a dyno run if you ever get a chance.
zobari
Report this Post12-18-2019 05:16 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dyno is a bit expensive 200euro I don't think pass a dyno run with my fiero.
I can drive at low rpm now, before the mod and changing the 6 inejctors and fuel pressure regulator the car vibrate a bit and no power under 2,5k after 2 gear now is far better and no vibration.
The car push hard at 5500 rpm I didn't tested after 5500rpm but maybe I Will test at 6000 rpm to see if the car keep the horsepower or not at 6000k but I Will test it after changing the y pipe and I come back to you.
zobari
Report this Post06-10-2020 06:52 AM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have modified my y pipe and remove restrictions (too much metal inside and the result that is decreased by 30% the volume before the downpipe).
with this upper intake and new y pipe, i can rev up to 6000 rpm without loss in performance.
The engine breath et keep power in higher rpm better.
But before 3000 rpm not much difference than before.
Ok that's not a corvette of course but a bit power and better rpm extension is good for me with this 2.8, i'm satisfied with these mods.
If you want see the final result in the engine bay :
video modded intake and ypipe fiero engine bay
[This message has been edited by zobari (edited 06-10-2020).]
La fiera
Report this Post06-10-2020 01:00 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very well done!!
Total ratings: 466
Report this Post06-10-2020 03:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice job... but get some shielding or exhaust wrap on that Y-pipe before you cook your ignition coil and ICM !
zobari
Report this Post06-10-2020 04:14 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Patrick,
Yes I have Aluminium sheet that I will cut and in order to protect the ignition coil and distributor.
I will make my own sheet shield this week.
I have seen it one year ago but thank you for your advice.
BillS
Report this Post06-13-2020 02:26 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
That reminds me of Igor in Young Frankenstein - "What hump?"
Would be interested to hear if there are any power gains.
zobari
Report this Post07-11-2020 03:21 PM Click Here to See the Profile for zobariSend a Private Message to zobariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a video with engine sound and I've installed an ezlip pro for the front bumper :
Video fiero with engine sound
[This message has been edited by zobari (edited 07-11-2020).]
