  Testing for faulty ECM?
Testing for faulty ECM? by Liam45
Started on: 12-29-2018 05:55 PM
Replies: 5 (342 views)
Last post by: Liam45 on 01-02-2019 12:30 PM
Liam45
Report this Post12-29-2018 05:55 PM Click Here to See the Profile for Liam45Send a Private Message to Liam45Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know any ways to test a Fiero ECM, its not throwing codes cars acting up misfires and after fire at steady power when driving, doesn't miss on acceleration. (V6 2.8) all ignition is new. Had issues with ignition components prior now cars driving, just cant be driven consistent..
Report this Post12-29-2018 06:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
even with all ignition parts being new, it could be a bad ground. connector, or wire. New parts are not necessarily good parts. If your SES light goes on when you turn the key, chances are good that the ECM is working.
Report this Post12-29-2018 11:54 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
First read my Cave, HE Ignition and Ground "Myth" notes
Yep Many problems are cause by wiring and grounds but many never understand common problem just in the ignition like just 1 crap screw can make big problems or kill the ICM.
After check HEI and other wiring (Wire Service and rest of section) and still have problems...
Need to check for iffy EGR or even fuel problems as both can fake ignition problems.
Liam45
Report this Post01-01-2019 07:34 PM Click Here to See the Profile for Liam45Send a Private Message to Liam45Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok yeah i have been checking out your cave and i have checked my grounds, so my car has had a bad egr solenoid prior to this issue but was running fine with its code 32 i believe it was, what ever the solenoid code is but could that be why the car is acting up?
Liam45
Report this Post01-01-2019 07:53 PM Click Here to See the Profile for Liam45Send a Private Message to Liam45Edit/Delete MessageReply w/QuoteDirect Link to This Post
Liam45
Member since Jul 2018
Actually i just revisited the cave im wondering about the tach filter my wires very iffy the connected actually partially broken, Im going to try to drive without it and see if it makes a difference. Keep ya updated thanks
Liam45
Report this Post01-02-2019 12:30 PM Click Here to See the Profile for Liam45Send a Private Message to Liam45Edit/Delete MessageReply w/QuoteDirect Link to This Post
Test drove her without the tach filter no difference unfortunately but gonna spend the day working on it hopefully I can figure it out.
