I never had problems installing any valve cover gaskets. Not even on old Ford 2.0l and 2.5l overhead cam engines.
Most have problems mainly because:
Way over tight and wreck gasket and cover.
Do Not Clean all metal of all oil and sealers won't seal.
They Do Not allow RTV silicon to "dry" before running the engine. "Dry to touch" is not same as total set time that can be a few hours to 1-3 days depending on several things including exact RTV formula used.
Worse is many use way too much RTV, w/ or w/o gaskets, and "boogers" in the engine can block drain holes etc and have more problems.
I used cork and rubber caskets w/ Fiero before w/o problems but Felpro PN VS50179T PermaDryPlus is far better for this engine.
It a "New" silicon gasket and parts to seal w/o crushing/bending. Come w/ new bolts etc
and install gasket dry.
Follow directions w/ it and if bolts/holes are oily/dirty do not torque in FSM or will wreck cover, break bolts, etc.
If cover is damage beyond help and many are because morons bent the seal face several to many times by now.
New cover
w/ a new cap is Dorman 264-905
Note that Dukes had 2 valve covers used at the factory.
One is made for gaskets. One made to work right w/o a gasket, just RTV silicon.
One for RTV have folded metal on bolt holes and "dents" on flat areas to maintain the correct gap for the RTV.
Felpro # above is made for either type and works w/ Dorman cover too. (Think Dorman is made for RTV too but not looking at my car at night.)
