  87 Connector Black with 5 wires 2 green, 1 tan, 1 Red 1 Orange - what does it do?
87 Connector Black with 5 wires 2 green, 1 tan, 1 Red 1 Orange - what does it do? by Simple Man
Started on: 10-08-2018 10:54 PM
Replies: 18 (549 views)
Last post by: Simple Man on 10-12-2018 10:10 PM
Simple Man
Report this Post10-08-2018 10:54 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
87 not sure what this connector does or controls. The PO cut the Red and Orange wires and the connector is just hanging there.
Any help is much appreciated
Chris Eddy
Report this Post10-09-2018 12:39 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It goes to the optional missile launcher, I would not worry about it.
fierosound
Total ratings: 287
Report this Post10-09-2018 03:06 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hard call.
A 4 cavity connector with Orange, Red, Green,Tan wires.
What's not working on your car??
There's other cut wires on the connector behind your hand too??
fierosound
Total ratings: 287
Report this Post10-09-2018 03:20 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
According the the Service Manual, this C1 plugs into the Ignition Switch itself.
This car does not run at present - does it? You got work to do.
I'm looking for a wiring diagram...
B3 is RED Power from fusible link A at the battery. (powers everything from START and RUN)
I3 ORANGE supplies power to the the 30amp circuit breaker for the power windows in the fuse block. (HOT in RUN)
TAN and GREEN wire have something to do with Key in Ignition Chime warning I think. (Green is ground for door open switches)
[This message has been edited by fierosound (edited 10-09-2018).]
Chris Eddy
Report this Post10-09-2018 05:51 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking at 2 old GM schematics, I show the ignition switch is..
Red on B2 and B3 (2 wires?) 12V source.
Brown on A is for accessory power
Orange on I3 is hot in run, ignition
Yellow on S is start
Pink on I1 is hot in run, bulb test, and start
So not sure about ignition switch..
But the headlights switch has..
Red on C
Orange on A
Yellow on D
White on F
Brown on E
That is much closer to your colors..
Simple Man
Report this Post10-09-2018 08:05 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fierosound the car does run! I bought the car this way and have been sorting out the electrical which has been a chore. Headlights, parking, brake and signals all work. Hazards are still not working.
The car has a 3800SC series II with a sebring steering column. All the wires from the Black connector have a home in the sebring column except the 2 grn and tan wires. If they are for the Chime and door open switches I can remove them.
The Orange wire has been rerouted and I will have to see if is still powers the power window fuse blocks. As I would like to use for the windows I will be installing.
Thanks for responding, much appreciate the help
Simple Man
Report this Post10-09-2018 08:10 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Simple Man
Member since Aug 2015
Red on C
Orange on A
Yellow on D
White on F
Brown on E
Chris, thank for the reply,
I do have two unaccounted wires coming out of the bundle of wire that feed the ignition. an orange and red. These are smaller in gauge and might be the Red on C and Orange on A that you are referring to?
This is the way I found the wires... not the type of work I would do
[This message has been edited by Simple Man (edited 10-09-2018).]
Chris Eddy
Report this Post10-09-2018 09:02 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its so hard to tell from this end.. where on the car are you taking pictures?
Simple Man
Report this Post10-09-2018 10:28 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
The picture is taken just to the right of the steering column. all the ignition wires and the twisted red and orange are coming out if the same bundle of wrapped wires. I have an 88 parts car and was able to confirm they all come from the same bundle/harness
fierosound
Total ratings: 287
Report this Post10-10-2018 12:00 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aha... that's why everything looks so messed up in that picture (cut wires everywhere).
[This message has been edited by fierosound (edited 10-10-2018).]
Total ratings: 207
Report this Post10-10-2018 07:50 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The two small green wires are the ground for the bulb test circuit that causes the temp Gage to peg when you turn the key ON.
The tan wire is your brake warning power feed that goes to the bias valve and emergency brake lever.
Simple Man
Report this Post10-10-2018 01:13 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the information, although I now have two different opinions. Under each repsonse I think I do not need the 2 grns or 1 tan wire connected.
The temp gauge is being handle in a different manner.
Not sure what the bias valve wire function is but the car has a wilwood system with proportioning valve etc.
Is the E brake wire to signal that the e brake is still on? I am using a different brake handle and haven't thought about much about that function.
For now I will tag the wires and leave in place.
Thank for the replies! the comments are very useful in sorting out this mess
Total ratings: 207
Report this Post10-10-2018 03:40 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grounding the tan/white wire turns on the BRAKE light on the cluster.
The lever has a switch that provides ground when ebrake is engaged.
Low pressure in the brake circuit allows the spool to move far enough to trip a grounding switch on the OEM bias valve.
The two green wires provide GROUND for the BULB CHECK function of the ignition switch. Pontiac made an error when wiring the Temp Gage and the HOT light, proding the bulb check ground to the Gage, rather than the light.
What I posted is not my opinion, it is the factual way that the vehicle is wired.
[This message has been edited by olejoedad (edited 10-10-2018).]
Simple Man
Report this Post10-10-2018 06:01 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again! I think I will keep the tan white wire and get that to work with my system. I believe the hand brake I am using has a switch or I might possibly have that part on my 88 fiero, will have to check it out and see how it functions.
Simple Man
Report this Post10-10-2018 07:56 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Simple Man
Does any one have any idea on the twist orange and red wires.
Thank you
Total ratings: 207
Report this Post10-11-2018 10:39 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Orange is typically switched battery voltage, and red is typically unswitched battery voltage.
Orange from IGN switch could be power windows
Red could be battery power to IGN switch.
Use DVM on continuity check setting to trace source of wires.
Orange may go to fuse box.
Red may go to BJT under C500.
Total ratings: 207
Report this Post10-11-2018 10:57 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
IGN switch terminal ID is as follows
B2 - Red from fuse link A battery power
B3 - Red from fuse link A battery power
A - brown, switched power to radio and battery fuse (hot in RUN)
I3 - Orange, switched power to WDO circuit breaker, Fan E fuse, HTR AC fuse (hot in RUN)
S - Yellow, Start signal to solenoid (hot in START)
I1 - Pink, switched power to TBI fuses, Turn B/U fuse, ECM fuse, Gage fuse, IGN coil via fuse link H ( hot in START, BULB TEST, RUN
G2 - tan/white, ground in bulb test for brake warning indicator
G1 - lt green, ground for temp Gage in bulb test (GM wiring error)
[This message has been edited by olejoedad (edited 10-11-2018).]
Simple Man
Report this Post10-11-2018 02:18 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! All the wires from the ignition switch identified.
The red twisted with the orange, in my picture, have no power with the key in the on or off position.
as suggested I will try to trace the wires when I get home tonight and see when comes up.
Simple Man
Report this Post10-12-2018 10:10 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did figure out what the twisted orange and red wires belonged too. They are part of the wiper circuit . THe connector for the wiper cicrcuit had only 1 wire attached and it was hot. THis wire was traced back to the Fuse block and the space for the wiper mototr
From the wiring diagram I can see the wires that were use purple grey etc.
So making some headway on this mess!!
[This message has been edited by Simple Man (edited 10-12-2018).]
