  TunerPro RT
TunerPro RT by fgt1988
Started on: 09-12-2018 08:44 PM
Replies: 6 (796 views)
Last post by: fgt1988 on 10-20-2018 08:16 PM
fgt1988
Report this Post09-12-2018 08:44 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone rembr if the acquisition file for our 86-88 V6 was for set for $24A.adx and if so is that the only file needed to load up and start scanning-- i saw a tutorial online where someone had loaded 3 files not sure why but it was a Bin ; XDF ; and ADX but he was working off a CD - Before registering Id like to get the free software to at least talk to my laptop and be able to see live data knowing all works well..
Joseph Upson
Total ratings: 88
Report this Post09-12-2018 10:16 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
3 files are required, XDF and ADX address the data arrangement and layout of the info held in the .bin file. Load both the XDF and ADX files in TunerPro for the Fiero and then open the file. It's been many years since I dealt with Fiero specific files but I believe $24A is for the 1985 V6 only which was also the file version capable of boost management.
Total ratings: 290
Report this Post09-13-2018 08:42 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only the .adx file is needed for scanning.
The bin file is the actual data on the disk. The .adx file defines how the data is arranged on the chip. Neither are needed unless you plan on burning chips.
The .adx file is the same for $24 and $24a. Only the .xdf file differs between the two. And the .bin file is different for every different version of chip. The three or four letters on the chip designate the version of the chip. There will be a different version of the chip
fgt1988
Report this Post09-21-2018 11:07 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks All for your time and support -
Cajun
Report this Post10-19-2018 03:30 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
fgt1988,
Did you ever get Tunerpro rt to work for you? If so, did you do any data logging?I
Total ratings: 290
Report this Post10-20-2018 03:11 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hit me up if you have questions with tunerpro rt.
fgt1988
Report this Post10-20-2018 08:16 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had not had the chance to run it again instead been using my old OBD1 that does a similar job with data streaming but lacks some readouts - Appreciate the help and follow up -----
