  85 2.5L fuel pressure, please help
85 2.5L fuel pressure, please help by Dmitchell80
Started on: 08-13-2018 05:01 PM
Replies: 12 (149 views)
Last post by: theogre on 08-14-2018 11:58 AM
Dmitchell80
Report this Post08-13-2018 05:01 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello again all, well I’ve rebuilt my engine and put everything back together. She will start beautifully and run great for about 1-2 mins. Then stall out with any throttle. Replaced fuel pump during rebuild, but upon checking I get 11 psi on start slowly dropped to 3-4 while running and that’s when it bogged out. Put a new fuel pump in again and it ran better I guess made it about 5 mins before bogged out, and stuck around 4-5 psi. Clamped off return,no diff. Shut engine off and with just priming fuel pump I can’t get it above 5 psi until everything is cooled down?what am I missing?
Total ratings: 461
Report this Post08-13-2018 05:21 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would suspect a leak inside the tank. Do you still have the original pulsator installed, or did you replace it with a short length the proper submersible hose?
[This message has been edited by Patrick (edited 08-13-2018).]
Dmitchell80
Report this Post08-13-2018 05:34 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for reply, never seen a pulsator either time I’ve pulled tank. I have replace the rubber hose from pump to steel pipe both times. Um I just primed pump it bit 12 psi, then dropped fast, did this a few times. Then clamped of return, primer and hit 14psi and stayed. Unclamped and only dropped to 11. Still sitting there minutes later
Total ratings: 461
Report this Post08-13-2018 05:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the proper submersible hose? And clamped tightly at both ends?
Those figures in your second post sound fine to me. Are you saying it's only when the engine warms up that the fuel pressure becomes low?
Dmitchell80
Report this Post08-13-2018 05:45 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Patrick,I am horrible at explaining things via writing. I see you are in BC with me. Although a lot lower and out of fire danger lol. I’d love to call you for a sec or you call me?
[This message has been edited by Dmitchell80 (edited 08-13-2018).]
Dmitchell80
Report this Post08-13-2018 05:49 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dmitchell80
Member since Jun 2018
Only because I’m confused as after I clamped return and released its now holding a steady 12psi. Which it’s never done. What could have clamping that off for a min have done? Should I try driving again?
Total ratings: 461
Report this Post08-13-2018 05:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just on my way out the door. If this doesn't get resolved in the meantime, it's possible we can discuss this later.
[EDIT] Last word before I run. Look in the TB and make sure the injector isn't leaking.
Dmitchell80
Report this Post08-13-2018 08:09 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
[/QUOTE]
It was, fuel pressure drop to about 4-5 psi after warm. Will need to check again in am, but seems adding back pressure from clamping hose has changed something. It’s holding steady at 11 psi now throughout rpm range. Can’t add load yet as I’ve had a few while working. Excited to see what happens in am though
Total ratings: 461
Report this Post08-13-2018 08:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm.... I think it's all becoming clear to me now.
Dmitchell80
Report this Post08-13-2018 08:55 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was a military mechanic for many many years. Autocorrect is my enemy still. Meant to say can’t check under load yet
Dmitchell80
Report this Post08-13-2018 08:58 PM Click Here to See the Profile for Dmitchell80Send a Private Message to Dmitchell80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dmitchell80
Which would have been “can’t under load yet”
Drink didn’t effect my work, just saying I can’t road test today
Total ratings: 461
Report this Post08-13-2018 10:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, I knew what you meant.
Report this Post08-14-2018 11:58 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replacement pumps "bad" are often:
Ebay/Amazon Counterfeit pumps. Buy local or use a AZ etc online.
Bad wiring to the pump.
Bad plumbing or TBI / fuel rail.
You pinched off return line eliminate TBI problems but not most others.
Fiero FP are Grounded in the Cabin and iffy Relay etc can "brown out" the +12v... See my Cave, Electric Motors and Wire Service
4cyl Does Not use the pulsator. Low pressure systems often don't need them.
6V/V8 high pressure systems does from factory but many aftermarket units do not need them because how their made.
