  Indy Air Cleaner Paint Color?
Indy Air Cleaner Paint Color? by ag9123
Started on: 07-20-2018 02:06 PM
Replies: 2 (239 views)
Last post by: ag9123 on 07-25-2018 11:04 AM
ag9123
Report this Post07-20-2018 02:06 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Would anyone happen to know the closest paint color for the Indy silver air cleaner and valve cover?
Couldn't find anything using search...
Thanks,
TG
1984 Indy Fiero
paulmckibben
Total ratings: 57
Report this Post07-21-2018 09:55 PM Click Here to See the Profile for paulmckibbenClick Here to visit paulmckibben's HomePageSend a Private Message to paulmckibbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Per Indy Guru Fred Bartemeyer, October 2015:
The Indy Valve Cover and Air Cleaner paint codes:
For quality Automotive Paint, It is a Chrysler color, CA1 Radiant Silver
Chrysler Code DT 9049
PPG Code 3556
Duplicolor makes a spray can version in either codes:
DSCC 338 Radiant Silver
DSGM 340 Silver Metallic
Spray can paint is close in color and texture, but leaves a little to be desired in a perfect replication and the spray can paint will not last as long.
Some notes for correct duplication:
1) Spray the silver over black primer or paint as the originals were dipped in black paint before being sprayed silver. The factory just grabbed standard iron duke valve covers and air cleaners out of the production parts bin and sprayed them silver.
2) The original paint was enamel, so if spraying urethane based single staged paint with a gun, reduce the gun pressure and increase the spray distance and spray pattern width to duplicate correct texture. And spray the parts like you have been standing on an assembly line all day and it is almost five o'clock with a pretty girl and free beer waiting for you at the bar after work. Thin spots, runs, sags and dirt particles in the paint are normal.
3) Paul KcKibben of Fierosails makes an excellent duplicate graphics kit in decal form or a reverse image mask that you can use to replicate the original screen printed graphics with an airbrush. http://www.fierosails.com/decal.html
Fred Bartemeyer
ag9123
Report this Post07-25-2018 11:04 AM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info Paul!
I was able to find both Duplicolor spray cans at Autozone:
I've got two air cleaner assemblies to work with
Looking forward to installing your decal kit on one and using the templates on the otrher...
1984 Indy Fiero
