| quote | Originally posted by KriPau:
I have a v6 with a 4-spd. I have around 0.590" on my flywheel. |
Sorry for the late reply, but this is likely going to be an issue.
A normal flywheel is around 0.83" and when surfaced they normally take 0.010" to 0.030" off. Yours has about 0.24" or 1/4" removed. I would be concerned that this flywheel is too thin and more prone to cracking or worse. I would try and get a new replacement.
| quote | Originally posted by Patrick: Sorry Gall, but I've got to disagree with you on this. Years ago, I had researched flywheel shim use... and decided it was definitely the route to go for my Fieros.
In theory to restore everything to the stock setup once a flywheel has been surface, you should install a flywheel shim equal to the amount of material removed. This works and there is nothing wrong with doing this.
However, in practice, with the stock fiero manual transmissions the spacer isn't needed. I say this based on 2 primary groups of data.
1. Every SBC swap with an Archie kit has the flywheel effectively 1/4" further from the throw out bearing (think of it as a flywheel that is effectively 1/4" thinner).
2. Variation in pressure plates, clutch mfg, clutch style, and clutch material results in the pressure plate fingers having variations in depth of up to 1/4 to 3/8" in.
These two items have been happening for decades and no one (including myself) ever focused on it. Sometimes they needed a longer pushrod to recenter the piston in the slave cylinder, but they worked... even being 0.250" off, so there isn't really a need to fuss over a 0.030" shim...
HTOB setups have really brought these issues to the forefront (at least for me) as their range of motion is much less than the stock Fiero setup and when you push them too far, you are pulling the transmission and replacing a $75-$100 part. This is why every setup using a HTOB need to be measured as there is no consistency in combination of parts.
