Series 2 and series 3 superchargers displace the same amount of air per revolution. |
That is technically correct but consider that the series III engine made 20 more horsepower than the series II with the same valve timing very minor differences to the ports and with the new supercharger. The gen V supercharger on the series III engine was modified to be more efficient.. The Gen V has larger air inlets, air outlets, ports inside the case and uses a larger throttle body.
While the displacement is the same the Gen V moves air at a lower temperature so dense air moves through it. In other words put heated air in a cylinder at a high temperature. I call that thin air. Now do the same with cooler dense air. Now wait for both to reach room temperature. The tank with the cooler dense air will take much longer to discharge.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 06-24-2018).]
