Example is See my Cave,
Electric Motors and read
Wire Service too and likely others.
service has list of main grounds around the car, fix/clean them first then check amp draw again.
example Rad Fan is grounded at left "inner fender" near HL assembly and common rust problem.
Fix/clear
all grounds in engine bay for same reason. Everything bolted to engine, trans bell, and car needs looking at.
Coat w/ silicon/brake grease. Safe for plastic insulation unlike most oils hate plastic.
Still see high loads then check for bad connectors etc.
check w/ engine etc off. Should pull < 0
.5 amps. Just OE radio far < that. (ECM standby power is another FL to same "box.") Anything more look for bad security, old cell phone parts, etc. Many find disused security audio etc still pulling power... PO had cell amp behind P side seat under the carpet but pulled out the rest when I got the car.
Carefully check HL motors... If warm/hot then likely have problem there too. Motor(s) can twitch too and even kill the battery. Unplug them while looking for other problems or fix/clean grounds near them.
