| quote | Originally posted by fierosound: Yup... 15mm and 18mm are the 2 sizes missing from common wrench/socket sets. Sets will usually go from 6 up to 13, 14, 17, 19 But you can often buy a single wrench/socket at better stores if your sets are missing them. |
Maybe very cheap sets. Most I've seen have 15mm but nearly all are missing 16mm 18mm. Many use near by SAE wrench but isn't same and often rounds off whatever.
Most 1/2" drive sets small size is 8mm or 9mm. Most 1/4" drive ~ 5mm to ~ 13mm
Fix Wrench sets often depends what type. 5 piece Flare wrenches have most common size nuts used and ends are set so can use two wrenches to fix many things like Fiero fuel filters. Many of them don't have 9-11mm and 16-18mm.
Chrysler also uses a lot of 18mm and have so since at least the 80's.
GM loves T10 T15 and T50 for most things But some others are used too like T30 for door skin bolts. Think T45 or T47 for Ebrake brackets for 84-87 rear calipers but god help you when you mess w/ them because most threads will strip before reaching torque spec. (Many rebuilt have the brackets attach. Get them is best.) Ford has use T50 for seat belts since the 70's.
Many times can use "wrong" size or SAE on Metric part to remove rusted heads/nuts.
Many are temped to use Allen wrench on Torx head... If works, just got lucky. Most times strips the heads and real tools then have problems or worse strips head tool or both.
