  WHAT is going on with this car ???! (Page 2)
WHAT is going on with this car ???! by Lou6t4gto
Started on: 05-09-2018 11:50 AM
Replies: 58 (1773 views)
Last post by: Lou6t4gto on 07-16-2019 04:17 PM
JMTUT
Report this Post06-24-2018 12:55 AM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alternate/OEM Part Number(s): 17068989, 17078272, 17079255, 17079582, 17079592, 17079596, 17079608, 17082060, 17082061, 17082066, 17083060, 17083082, 17083083, 17084060, 17084061, 17084065, 17084066, 17084067, 17084082, 17084083, 17085061, 17085062, 17085065, 17085068, 17085069, 17085082, 17085083, 17086063, 17086065, 17086085, 17086108, 17086109, 17086110, 17086111, 17086113, 17110359, 17110362, 17110368, 17110369, 17110376, 17110647, 17110671, 17110675, 17110759, 17110762, 17110768, 17111164, 17111388, 89053151
you can find it on Rock Auto
https://www.rockauto.com/en...ssure+regulator,6124
They also have the Throttle body rebuild kit on closeout for $12.99
JMTUT
Report this Post06-24-2018 12:59 AM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
JMTUT
Member since Oct 2017
When I rebuilt my TB the entire EGR passage was plugged.
JMTUT
Report this Post06-24-2018 01:02 AM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
JMTUT
This is what it looked like after cleaning.
Lou6t4gto
Report this Post07-02-2018 01:39 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think maybe Today I will pull off the TB and look at the EGR tunnel under it. It's Never been Off as far as I know.
Lou6t4gto
Report this Post07-02-2018 01:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
AND, take the red 3800SC car out of storage for it's "Monthly", well " Bi Monthly" ride LOL
crashyoung
Report this Post07-02-2018 01:52 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Lou6t4gto:
I Answered that Too Quickly ! if I turn On the key (not start), it Does Nothing. If I "Crank it", it will start and hold 13 PSI. As soon as the key is
"Shut Off", it goes to Zero within 1-2 seconds. ** NO Pressure only turning the key to "On" Position.** Only pressure if it's cranked and running.
A dollar says fuel pump relay.
If the pump only comes on with oil pressure, then the ECM isn't able to run it when you turn the key to on. If it stalls at a stop, you may have a bad oil sender too, or low pressure!!
Crash
Lou6t4gto
Report this Post07-02-2018 01:57 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Pump DOES "come on" with key turned on, just No Pressure the first time. ( only 6 psi the 2nd time). then won't hold it.
I have 2 OIL Gauges, 1 "original" and 1 "mechanical". the original will say 60-80 psi, mechanical says 40 ! when the car "idles down" in gear the mechanical stays at 30, the Original jumps all over the place, but never to "0".
Report this Post07-02-2018 03:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect the short piece of hose in the tank has either rotted and/or become partly detached.
Lou6t4gto
Report this Post07-06-2018 02:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did order a TB rebuild kit, Waiting. but will pull the tank as a Last resort (Of course it's FULL !) LOL
Lou6t4gto
Report this Post07-10-2018 08:05 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
gOT AND INSTALLED THE NEW THROTTLE body "rebuild kit w/ regulator", absolutely No Change. Still, turn on key, the pump whirs, but no Pressure. do it 5-6 times, no pressure. crank it and it will start and run and hold 12 PSI "while running". turn off the key and Immediately goes to 0, zip, nothing. turn on the key, pump whirs, No Pressure. Seems it will hold 12-13 psi WHILE IT'S RUNNING, but won't do Any pressure if Not Running ! boy I hate to drop the full tank if that's not it ! LOL
Spoon
Total ratings: 61
Report this Post07-10-2018 09:36 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you pull the tank make sure your using submersible fuel hose. Super expensive but better than pulling a tank 2 or 3 times.
Good video here.
https://www.youtube.com/watch?v=aZPwLaSCHTI
Read this too,
http://www.napabeltshose.co...sible-hose.pdf?la=en
Spoon
[This message has been edited by Spoon (edited 07-10-2018).]
Lou6t4gto
Report this Post07-10-2018 10:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats what I used about 3 years ago when I replaced the pump last time, about $7 a foot ! I'll take a look at the LINKS. Thanks
Lou6t4gto
Report this Post07-10-2018 10:28 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
OK, NAPA hose it will be. Thanks
Spoon
Total ratings: 61
Report this Post07-11-2018 07:59 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you get a section that shows SAE 30R10 on the hose. Even if the price is correct they could still cut from the wrong spool thinking its all fuel injection hose. Don't trust the box its in either!
Spoon
Lou6t4gto
Report this Post08-03-2018 01:20 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I still have not replaced the fuel line in the tank, but Have driven it a number of times (With No Problems!), will eventually R&R the fuel line.
Lou6t4gto
Report this Post08-28-2018 01:12 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
New FUEL PRESSURE Reg and rebuilt TB !, It ran ok for about 50 miles, Now , back to stalling at idle in gear at light. no sputtering, just shut off ! It Will re-start. IS THERE ANYTHING ELSE LEFT ???
Lou6t4gto
Report this Post09-08-2018 01:11 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump ?
Joseph Upson
Total ratings: 88
Report this Post09-11-2018 08:46 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace the fuel pump, it has a built in check valve that may have failed which will allow it to deliver sufficient pressure while it is running, but not hold it when it is not. The pressure drop off appears to be too fast to represent a leak on the pressure side. A leak that bad should make it difficult to achieve sufficient pressure and should get worse with use in the typical fashion a hose leak would. Failure to generate fuel pressure immediately upon being turned on indicates you have a fuel pump problem. Bad pumps can run and generate, intermittent, little and no pressure.
Put unleaded fuel in it. Despite your feeling it runs better with premium. Premium takes longer to burn in a relatively low compression engine and could contribute to a rich condition, especially if engine wear resulting in lower than normal cylinder pressure is present. Consider a compression test. When I ran premium fuel in a low mileage 85 2.8L V6 Firebird, it became noticeably sluggish and it ran hotter. I never did it again the symptoms were so immediate and obvious.
Intermittent stalling in the presence of the parts you have replaced would cause me to consider the distributor also. I had one in a Fiero that would run the car 3-4 miles and quit, then startup after cooling a few short minutes and repeat the cycle.
If that doesn't fix it, the ECM is next.
Lou6t4gto
Report this Post07-16-2019 04:17 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
was a SPLIT rubber line IN the tank, replaced the Pump And line. Car STILL STALLS !
