  Should the radiator cap be cold when engine is at operating temperature?
Should the radiator cap be cold when engine is at operating temperature? by cebix
Started on: 04-27-2018 01:59 PM
Replies: 15 (862 views)
Last post by: olejoedad on 04-28-2018 03:21 PM
cebix
Report this Post04-27-2018 01:59 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
A simple question but... no idea if it's supposed to work like this. '85 duke auto w/AC.
My temp gauge fluctuates pretty badly since yesterday when the car is up to temp and standing still. It stays on the second mark all day when driving even crawling.
But when I come to a stop it rises pretty fast to the red - even my idiot light turned on today but just give it a little gas and it pulls down to the second mark in a matter of 3 seconds. No real sings of overheating though I did blow some coolant out of the reservoir tank some days before - but I guess that's because I added too much to the tank earlier.
All hoses are hot, normally hot I guess so there's flow through the radiator and the t-stat opens up. The radiator cap is dead cold though and I hear some hissing when I shut off the engine from the cap. It's the proper non-vented cap. No leaks anywhere found.
What could this be? A bad gauge, sensor? Air bubble in the system? Something worse? Driving 80mph all day and it stays dead on the second mark. Temperature's here are ~70 outside. Gauge shows proper cool when cool.
EDIT: My radiator fan works both using the A/C buttons and on its own but it rarely comes on by itself. Mostly only after I shut off the car and turn on the ignition after a few minutes.
EDIT2: I had the temp gauge fix done years ago that swaps the bulb test from the gauge to the light so that works too. Gauge doesn't peg and the light comes on when it should according to the gauge. Thermostat cap is brand new and the thermostat is a few years old. I do have a brand new one lying around just in case.
[This message has been edited by cebix (edited 04-27-2018).]
Report this Post04-27-2018 03:14 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cap and even parts of radiator Can be cool/cold w/ engine warm to hot. more so on Fiero because no engine heat soaking the front of car.
Rad Cap is on cold side plastic tank that's a poor conductor of heat.
Many times Rad Overflow parts are cool/cold too.
Weather can effect front heating and most of front parts like HL lift assemblies can be cool/cold when weather is cool/cold.
[This message has been edited by theogre (edited 04-27-2018).]
Total ratings: 207
Report this Post04-27-2018 03:15 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is your overflow tank 1/2 full cold?
When warm, does the level of the overflow tank rise?
cebix
Report this Post04-27-2018 03:31 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
When cold it's almost full - that's my bad, I filled it up too much. Yeah, it rises when heating up and I guess that's why it overflowed a few times before, now it's a little over full when hot but not pouring out.
Total ratings: 207
Report this Post04-27-2018 03:39 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
When cold, if you loosen the front cap, does fluid come out, or do you hear air coming out?
cebix
Report this Post04-27-2018 04:00 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, when cold it all sits there still.
EDIT: Oh wait, you mean the rad cap, not the reservoir cap? Didn't check that. Will do that tomorrow since the engine's still hot now. It's 10pm here right now.
cebix
Report this Post04-27-2018 04:27 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
cebix
Member since May 2011
Okay, got around to it - it was already cold so I unscrewed the cap.
No air hissing. No coolant flowing out too though - it was level with the lower side of the cap so I could touch it but it wasn't flowing out on its own. So it was definitely filled with coolant but I thought it would be pouring out since I think this is not the lowest point in the system. The car sits level now. Is this good or is the overall coolant level too low?
Total ratings: 207
Report this Post04-27-2018 05:28 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace the front cap and pull the thermostat and fill the system.
cebix
Report this Post04-27-2018 05:33 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, that sounds reasonable. I get the idea of filling the system with the thermostat out but why do I need to replace the front cap? It was replaced ~2 years ago. What can make it go bad and which of my symptoms tell the story that it has gone bad?
I will replace it anyway since it seems to have rusted a little but a little knowledge in what to look for would help. Thanks!
Total ratings: 207
Report this Post04-27-2018 05:59 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I meant reinstall the cap.
If you fill from the back, it will over flow if the front cap is off.
I will wager you already knew that!
cebix
Report this Post04-27-2018 06:04 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool, now I get it. I thought you meant the cap was bad and it needs replacing with a new one. Will try that tomorrow, test drive and let you all know. Thanks for the suggestions.
Total ratings: 207
Report this Post04-27-2018 06:52 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any time the coolant temp gage starts fluctuating rapidly, it's a good sign of an air pocket or low coolant.
You are very welcome!
cebix
Report this Post04-28-2018 11:59 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I guess it's solved. Think it was an air pocket. Not a big one though, it only took about ~200ml of coolant until it topped off. Now the gauge's steady and works how It should I guess.
Burping the system was impossible though. Keeps foaming up on me after starting cold for ~30 seconds and the coolant level doesn't drop so there's no way to add more.
Though I do hear the rad cap hissing just about when the radiator fan kicked on. Could this be where some air is getting in? Or is it normal for it to "hiss" and burp a bit?
Total ratings: 207
Report this Post04-28-2018 01:48 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the coolant heats up, it expands and also the system pressure increases.
At some point the pressure exceeds the rating of the cap, it opens slightly and coolant (and air, remember the top of the radiator is designed to be an air trap) is forced into the overflow tank.
Upon cooling, the coolant contracts, pressure drops to the point of a slight vacuum and the coolant is pulled back into the system. The tank discharges through the bottom to keep air from being introduced into the system.
cebix
Report this Post04-28-2018 02:05 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, the cooling system was always some kind of mystery to me - especially on the Fiero since it's a little "different".
Thank you for your guidance, this means a lot.
Total ratings: 207
Report this Post04-28-2018 03:21 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You, sir, are very welcome.
I'm glad it worked out and I was of some assistance.
